with this project you can monitoring your MikroTik Router resources on your Blynk app remotely
Materials:
MikroTik Router with USB port. ( like RB951Ui or any router that have USB port )
ESP8266 NodeMCU
MicroUSB cable to programming the NodeMCU and for connecting the NodeMCU to your MikroTik Router.
Guide:
1- install the LCD package on your MikroTik Router from the official MikroTik download page.
2- Upload the below Arduino Sketch to your NodeMCU
char auth[] = "92221bbfc31d48d0979aaff275b3730b";
char ssid[] = "MikroTik Tesla";
char pass[] = "12345678";
char server[] = "10.5.5.18";
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Blynk.begin(auth, ssid, pass, server, 8080);
timer.setInterval(1000L, prt);
void prt()
String content = ""; //null string constant ( an empty string )
char character;
while(Serial.available()) {
character = Serial.read();
content.concat(character);
if (content != "") {
Blynk.virtualWrite (V0, content);
3- Connect your NodeMCU to your MirkroTik Router usb port.
4- enabling the LCD mode from winbox system > LCD
5- in LCD settings check the Enabled
6- select the Type as ax89063
select the port to usb1 or other ( on your router the port maybe usb2 or anything ) then click on apply.
7- in the LCD page you can select and enable your favorite resources. Iām select this options you can see in below picture
8- in Blynk App add the Terminal widget then select V0
Finally you can monitoring your MikroTik Router resources from the blynk app
if not working, just rebooting your router
