i m having problem migrating my program to be able to use in the new blynk app. ive tried adding the template id, device name, as well as the auth token and it seems to connect. but the problem is, it wont work like it used to in the old blynk app. the data wont be displayed on the lcd. what should i do? thanks for those wholl help
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPLyMhBYuUA"
#define BLYNK_DEVICE_NAME "Monitoring System"
WidgetLCD lcd(V2);
String data;
String I;
char auth[] = "Nt7IlQ1LKrJATx0Li43e7Im01kN_jsAr";
char ssid[] = "realme C12";
char pass[] = "qwertyuiop";
String myString; // complete message from arduino, which consists of sensors data
char rdata; // received charactors
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent() {
Blynk.virtualWrite(V1, millis() / 1000);
timer.setInterval(1000L, sensorvalue1);
if (Serial.available() == 0 ) {
if (Serial.available() > 0 ) {
rdata = Serial.read();
myString = myString + rdata;
Serial.print(rdata);
if ( rdata == '\n') {
I = getValue(myString, ',', 0);
myString = "";
lcd.print(0, 0, "Resistance:");
void sensorvalue1() {
data = data + I;
lcd.print(0, 1, data);
data = "";
lcd.clear();
String getValue(String data, char separator, int index) {
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i + 1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
