I making a project with the mega connected with ESP8266 via hardware serial1.
Without the PubSubClient liberary i have managed to connect to my wifi.
Now i want to publish something to my own (rasbarryPi) Hassio MQTT server.
For that i need the PubSubCient liberary.
But this liberary asks for a PubSubClient client("
What ever i put in stead of the questionsmarks i get errors.
When connecting to MQTT via wemosD1 i use the ESP8266WiFi.h;
But on the mega that doesn’t work. On the mega i have to use ESP8266_Lib.h;
This liberary is included in the blynk default example skatches under -> boards wifi -> ESP8266 shield.
Different liberary so copie - past from one skatch to the other doesn’t work.
Kan some please take a look? Maybe PubSub liberary doesn’t work with hardware serial com with esp8266?
Working code on WemosD1 with mqtt:
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "******";
const char* password = "******";
const char* mqtt_server = "******";
WiFiClient espClient;
PubSubClient client(espClient);
int SwitchedPin = D4;
String afzuiging;
String strTopic;
String strPayload;
void setup_wifi() {
delay(100);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("IP address: ");
void callback(char* topic, byte* payload, unsigned int length) {
payload[length] = '\0';
strTopic = String((char*)topic);
Serial.println(strTopic);
if(strTopic == "ha/afzuiging")
afzuiging = String((char*)payload);
if(afzuiging == "ON")
Serial.println("ON");
digitalWrite(SwitchedPin, LOW);
Serial.println("OFF");
digitalWrite(SwitchedPin, HIGH);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("arduinoClient","admin","admin")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.subscribe("ha/#");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(SwitchedPin, OUTPUT);
if (!client.connected()) {
reconnect();
client.loop();
And this is the Mega NOT working code:
#include <ESP8266_Lib.h>
char auth[] = "************";
char ssid[] = "*****";
char pass[] = "********";
//Hardware Serial on Mega, Leonardo, Micro...
#define EspSerial Serial1
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
///////////////////////////////////MQTT//////////////////////////////////
PubSubClient client(ESP8266 wifi);
String afzuiging;
String strTopic;
String strPayload;
////////////////////////////////////TFT/////////////////////////////////
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <FreeDefaultFonts.h>
// ALL Touch panels and wiring is DIFFERENT
// copy-paste results from TouchScreen_Calibr_native.ino
const int XP = 8, XM = A2, YP = A3, YM = 9; //320x240 ID=0x9341
const int TS_LEFT = 73, TS_RT = 896, TS_TOP = 124, TS_BOT = 910;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on1_btn, on2_btn, on3_btn, off_btn;
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.y, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.x, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define Speed1Pin 31
#define Speed2Pin 32
// digitalWrite(SwitchedPin, LOW);
// digitalWrite(SwitchedPin, HIGH);
void reconnect() {
if (client.connect("arduinoClient","*****","*******")) {
delay(5000);
void setup(void)
pinMode(Speed1Pin, OUTPUT);
pinMode(Speed2Pin, OUTPUT);
uint16_t ID = 0x9341;
tft.begin(ID);
tft.setRotation(1); //PORTRAIT
tft.fillScreen(BLACK);
tft.drawRect(0, 0, 319, 240, WHITE);
tft.setFont(&FreeSans9pt7b);
tft.setCursor(50, 30);
tft.setTextColor(WHITE);
tft.setTextSize(1);
tft.print("WIFI CONNECTING...");
///////////////////////////////WIFI/////////////////////
tft.setTextSize(1);
tft.print("CENTRALE AFZUIGING");
tft.fillRect(150, 50, 155, 100, RED);
void loop(void)
/////////////////////WIFI////////////////////////////
reconnect();
client.loop();
//__________________________________________________
This is the arduino IDE compile error:
Arduino:1.8.9 (Mac OS X), Board:“Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
/var/folders/wf/4vz3b4_x6658s321739l7vjc0000gn/T/arduino_modified_sketch_921032/Afzuiging_TFT_side_V4_test_HASSio.ino: In function ‘void reconnect()’:
Afzuiging_TFT_side_V4_test_HASSio:158:18: error: request for member ‘connected’ in ‘client’, which is of non-class type ‘PubSubClient(ESP8266)’
exit status 1
