Is Blynk working on LoRa based data transmission, If yes can You send me a basic code that I could work on.
Yes.
It is not yet done.
Yes, I confirm that Lora work correctly with Blynk trough Node red and TTN (the things Network) or node to node. If you are using TTN you need first a Gateway and after a lorawan, the link with blynk is not one your lorawan but in Node-red.
