Looks a bit like “flooding”?
Try changing the frequency from 5 seconds to 70 seconds…
Obvious question but have you set up email widget on the app fully?
Hi Dave!
I made it work correctly!
Next challenge (but I don’t know how to code): if temperature stays above X degrees for more than Y minutes…
Thanks!
that’s great, but how did you do it?!
that is hard, it is easier to see if temp is above X every Y minutes.
otherwise you have to start using an average or median to know if the temperature STAYS above X
in my HVAC code, i use runningMedian to smooth out my temps and know that when i look at the temps every X minutes, i know that the temps is not an aberration, so it is reliable enough to use to make decisions…
or more simply you can check temp every X/5 minutes and keep a count of how many times during X the temp is higher than Y - if it is higher than Y 5 times, then trigger your warnings…???
My code (didn’t change too much according to the last code):
#define ONE_WIRE_BUS 10
#define TWO_WIRE_BUS 11
#include <OneWire.h>
#include <ESP8266_Lib.h>
#include <TimeLib.h>
DallasTemperature DS18B20(&oneWire);
OneWire twoWire(TWO_WIRE_BUS);
DallasTemperature DS18B20B(&twoWire);
char auth[] = "TOKEN";
char ssid[] = "Papa-Rica Wi-Fi";
char pass[] = "password";
//variables
float tempCong;
float tempResf;
boolean sentNotice1;
boolean sentNotice2;
SimpleTimer timerFridge;
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set console baud rate
// Set ESP8266 baud rate
DS18B20.begin();
DS18B20B.begin();
timer.setInterval(5000L, sendTemps); // Temperature sensor polling interval (5000L = 5 seconds)
timerFridge.setInterval(10000L, monitorFridge);
void sendTemps()
DS18B20.requestTemperatures(); // Polls the sensors
DS18B20B.requestTemperatures();
tempCong = DS18B20.getTempCByIndex(0); // Gets first probe on wire in lieu of by address
tempResf = DS18B20B.getTempCByIndex(0);
Blynk.virtualWrite(4, tempCong);
Blynk.virtualWrite(5, tempResf);
timerFridge.run();
void monitorFridge()
if (tempCong >= -7 && !sentNotice1)
Blynk.email("rodrigo.cavalheiro@gmail.com", "Congelados > Alerta de temperatura", "Câmara de congelados acima de -8C!");
sentNotice1= 1; // mark it sent so it doesnt loop and flood
else if(tempCong < -7)
sentNotice1= 0;
if (tempResf >= 11 && !sentNotice2)
Blynk.email("rodrigo.cavalheiro@gmail.com", "Refrigerados > Alerta de temperatura", "Câmara de refrigerados acima de 11C!");
sentNotice2= 1; // mark it sent so it doesnt loop and flood
else if(tempResf < 11 )
sentNotice2= 0;
About your suggestion:
This is exactly what I want.
I’m working on it. If you have any advice, please share it!
Thank you!
If the temperature is over X, trigger the temperature timer.
|20°c 10secs|
|TRIGGERED| <=Not like this.
The temperature timer should check every D secs till It exceeds Y. (Where D is a constant integer lower than Y, 2 is recommended)
If it falls before Y, stop.
If it exceeds Y, send the e-mail.
