Same problem here [19] Blynk v0.3.9 on Arduino Uno [520] Connecting to RingOfFire [3812] 0018000902-AI03 [6947] 192.168.1.3 [6976] Connected to WiFi [114638] Login timeout [125346] Login timeout [134193] Ready (ping: 124ms). [150294] Login timeout [159056] Ready (ping: 125ms).
Code:
#define ONE_WIRE_BUS 10
#include <OneWire.h>
#include <ESP8266_Lib.h>
#include <TimeLib.h>
DallasTemperature DS18B20(&oneWire);
char auth[] = "03123be3ecbf4ab4b275528b15a36b2e";
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set console baud rate
// Set ESP8266 baud rate
DS18B20.begin();
timer.setInterval(1000L, sendTemps); // Temperature sensor polling interval (5000L = 5 seconds)
float tempCong;
void sendTemps()
DS18B20.requestTemperatures(); // Polls the sensors
tempCong = DS18B20.getTempCByIndex(0); // Gets first probe on wire in lieu of by address
Blynk.virtualWrite(4, tempCong);
if (tempCong >= -8)
//Blynk.notify("Temperatura alta!");
Blynk.email("rodrigo.cavalheiro@gmail.com", "Alerta de temperatura", "Câmara de congelados acima de -8C!");
delay(100000);
The issue you ask yourself? Well when if (tempCong >= -8) is TRUE, then it will loop the Blynk.email function hundreds of times and you will be disconnected from the cloud server due to flooding.
Also put Blynk.run() first in the loop and remove the silly delay(100000); because that will also cause a disconnect.
Avoid using delays completely.
yup put it behind a timer at 500ms, then make sure you set a boolean after you send the email so that it only sends once.
void monitorFridge(){
if (tempCong >= -8 && !sentNotice)
sentNotice= 1; // mark it sent so it doesnt loop and flood
} else if(tempCong != -8) {
sentNotice= 0;
I can read the temperatures in the app but I don’t receive the emails.
Please notice that there are 2 temp sensors.
Both boolean variables were declared correctly.
My code:
DS18B20.begin();
DS18B20B.begin();
timer.setInterval(5000L, sendTemps); // Temperature sensor polling interval (5000L = 5 seconds)
void sendTemps()
DS18B20B.requestTemperatures();
tempResf = DS18B20B.getTempCByIndex(0);
Blynk.virtualWrite(5, tempResf);
if (tempCong >= -8 && !sentNotice1)
sentNotice1= 1; // mark it sent so it doesnt loop and flood
} else if(tempCong < -8) {
sentNotice1= 0;
if (tempResf >= 11 && !sentNotice2)
Blynk.email("rodrigo.cavalheiro@gmail.com", "Alerta de temperatura", "Câmara de congelados acima de 11C!");
sentNotice2= 1; // mark it sent so it doesnt loop and flood
} else if(tempResf < 11 ) {
sentNotice2= 0;
timerFridge.run();
Blynk.email("rodrigo.cavalheiro@gmail.com", "Congelados > Alerta de temperatura", "Câmara de congelados acima de -8C!");
sentNotice1= 0;
Blynk.email("rodrigo.cavalheiro@gmail.com", "Refrigerados > Alerta de temperatura", "Câmara de refrigerados acima de 11C!");
sentNotice2= 0;
Also, I put a timerFridge.setInterval(5000L, monitorFridge); in void setup()
#define TWO_WIRE_BUS 11
OneWire twoWire(TWO_WIRE_BUS);
DallasTemperature DS18B20B(&twoWire);
char auth[] = "token";
char ssid[] = "RingOfFire";
char pass[] = "xxxxxxx";
//variables
float tempCong;
float tempResf;
boolean sentNotice1;
boolean sentNotice2;
SimpleTimer timerFridge;
DS18B20.begin();
DS18B20B.begin();
void sendTemps()
timerFridge.run();
sentNotice1= 0;
sentNotice2= 0;
//variables
float tempCong;
float tempResf;
DS18B20.begin();
DS18B20B.begin();
timer.setInterval(5000L, monitorFridge);
void sendTemps()
void monitorFridge() {
sentNotice1 = 1; // mark it sent so it doesnt loop and flood
else if (tempCong < -8)
sentNotice1 = 0;
sentNotice2 = 1; // mark it sent so it doesnt loop and flood
else if (tempResf < 11 )
sentNotice2 = 0;
you should add in some serial prints to see if/where the code is not working…
serial.Print(F("temp is high! just tried to send email"));
serial.Print(F("temp is OK! no need to send email"));
sentNotice1 = 0;
sentNotice2 = 0;
I changed the code to include serial prints, tried to change the email but email still not working.
Serial monitor:
[19] Blynk v0.3.10 on Arduino Uno
[520] Connecting to Papa-Rica Wi-Fi
[3585]
OK
[6727] 192.168.1.100
[6757] Connected to WiFi
temp is high! just tried to send email[14504] Login timeout
[26024] Login timeout
[36716] Login timeout
[46937] Ready (ping: 1589ms).
Even when I try to send a “Success login” notification or email on void setup() it completely ignores the command.
Do I have to call any library for notifications or email?
Output from last code:
[525] Connecting to Papa-Rica Wi-Fi
[3592] 0018000902-AI03
[6731] 192.168.1.100
[6761] Connected to WiFi
[14529] Login timeout
[25542] Ready (ping: 1588ms).
[43947] Heartbeat timeout
[53080] Ready (ping: 1589ms).
[138557] Login timeout
