I lost my old computer. It got shocked with lightning strike. Very exciting.
So I decided to use Linux MINT as my new platform. The install went as easy as could be expected. The server started and I opened the ports on the router. I went to the admin web portal and it opened. I attempted to login but that is were I am stuck. I set the server.properties
admin.email=admin@blynk.cc
admin.pass=admin
Not sure why this does not work…
I also tried to login via the blynk app on my phone without any luck,
Any help will be appreciated.
Here is a copy of the log
12:49:04.269 INFO - Using data dir ‘blynk-data’
12:49:04.295 DEBUG- Starting reading user DB.
12:49:04.516 DEBUG- Reading user DB finished.
12:49:04.517 INFO - Region : local. Host : *.blynk.cc.
12:49:04.541 INFO - Using native epoll transport.
12:49:04.804 INFO - Initializing gmail smtp mail transport. Username : [REDACTED]. SMTP host : smtp.gmail.com:587
12:49:04.833 INFO - Reports : 0
12:49:04.834 INFO - Didn’t find Let’s Encrypt certificates.
12:49:04.834 INFO - Automatic certificate generation is turned ON.
12:49:04.834 INFO - Using native openSSL provider.
12:49:04.834 WARN - ATTENTION. Server certificate paths (cert : ‘/home/michael/Documents/Blynk-server/./server_embedded.crt’, key : ‘/home/michael/Documents/Blynk-server/./server_embedded.pem’) not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
12:49:05.259 DEBUG- hard.socket.idle.timeout = 10
12:49:05.286 INFO - HTTP API and WebSockets server listening at 8080 port.
12:49:05.287 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
12:49:05.288 INFO - Mqtt hardware server listening at 8440 port.
12:49:37.758 DEBUG- Unsecured connection attempt or not supported protocol. Channel : /10.0.0.236:38582. Reason : javax.net.ssl.SSLHandshakeException: error:10000412:SSL routines:OPENSSL_internal:SSLV3_ALERT_BAD_CERTIFICATE
12:49:41.646 TRACE- HTTPS connection detected.
12:49:41.700 TRACE- Mapping from /admin to /admin
12:49:41.700 TRACE- In http and websocket unificator handler.
12:49:41.704 TRACE- Initialized admin pipeline. [SslHandler#0, HttpsServerCodec, HttpsServerKeepAlive, HttpsObjectAggregator, HttpChunkedWrite, HttpUrlMapper, UploadHandler#0, OTAHandler#0, AdminAuthHandler#0, AuthCookieHandler#0, CookieBasedUrlReWriterHandler#0, StaticFileHandler#0, OTALogic#0, UsersLogic#0, StatsLogic#0, ConfigsLogic#0, HardwareStatsLogic#0, HttpAPILogic#0, NoMatchHandler#0, DefaultChannelPipeline$TailContext#0]
12:49:41.705 TRACE- Is unpacked.
12:49:41.705 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/login.html
12:49:41.742 TRACE- Mapping from /static/css/blynk.css to /static/css/blynk.css
12:49:41.743 TRACE- Is unpacked.
12:49:41.743 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/css/blynk.css
12:49:41.755 TRACE- Mapping from /static/js/enc-base64-min.js to /static/js/enc-base64-min.js
12:49:41.755 TRACE- Is unpacked.
12:49:41.755 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/enc-base64-min.js
12:49:41.783 TRACE- HTTPS connection detected.
12:49:41.784 TRACE- Mapping from /static/js/sha256-min.js to /static/js/sha256-min.js
12:49:41.784 TRACE- Is unpacked.
12:49:41.784 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/sha256-min.js
12:49:41.807 TRACE- HTTPS connection detected.
12:49:41.808 TRACE- Mapping from /static/js/login.js to /static/js/login.js
12:49:41.809 TRACE- Is unpacked.
12:49:41.809 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/login.js
12:49:41.809 TRACE- HTTPS connection detected.
12:49:41.811 TRACE- HTTPS connection detected.
12:49:41.811 TRACE- Mapping from /static/js/jquery-2.2.2.min.js to /static/js/jquery-2.2.2.min.js
12:49:41.811 TRACE- Is unpacked.
12:49:41.811 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/jquery-2.2.2.min.js
12:49:41.811 TRACE- Mapping from /static/js/core-min.js to /static/js/core-min.js
12:49:41.812 TRACE- Is unpacked.
12:49:41.812 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/core-min.js
12:49:41.823 TRACE- HTTPS connection detected.
12:49:41.825 TRACE- Mapping from /static/js/bootstrap.min.js to /static/js/bootstrap.min.js
12:49:41.826 TRACE- Is unpacked.
12:49:41.826 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/js/bootstrap.min.js
12:49:41.895 TRACE- Mapping from /favicon.ico to /static/favicon.ico
12:49:41.895 TRACE- Is unpacked.
12:49:41.895 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/favicon.ico
12:49:45.585 TRACE- Mapping from /admin/login to /admin/login
12:49:45.585 TRACE- In http and websocket unificator handler.
12:49:45.586 TRACE- Initialized admin pipeline. [SslHandler#0, HttpsServerCodec, HttpsServerKeepAlive, HttpsObjectAggregator, HttpChunkedWrite, HttpUrlMapper, UploadHandler#0, OTAHandler#0, AdminAuthHandler#0, AuthCookieHandler#0, CookieBasedUrlReWriterHandler#0, StaticFileHandler#0, OTALogic#0, UsersLogic#0, StatsLogic#0, ConfigsLogic#0, HardwareStatsLogic#0, HttpAPILogic#0, NoMatchHandler#0, DefaultChannelPipeline$TailContext#0]
12:49:45.587 DEBUG- POST : /admin/login
12:49:45.598 TRACE- Mapping from /admin to /admin
12:49:45.598 TRACE- Is unpacked.
12:49:45.598 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/login.html
12:49:49.076 TRACE- Mapping from /admin/login to /admin/login
12:49:49.076 DEBUG- POST : /admin/login
12:49:49.079 TRACE- Mapping from /admin to /admin
12:49:49.079 TRACE- Is unpacked.
12:49:49.079 TRACE- Getting file from path /home/michael/Documents/Blynk-server/static/login.html
