11:41:39.709 INFO - Using data dir ‘blynk-data’
11:41:39.734 DEBUG- Starting reading user DB.
11:41:39.955 DEBUG- Reading user DB finished.
11:41:39.956 INFO - Region : local. Host : *.blynk.cc.
11:41:39.978 INFO - Using native epoll transport.
11:41:40.241 INFO - Initializing gmail smtp mail transport. Username :. SMTP host : smtp.gmail.com:587
11:41:40.269 INFO - Reports : 0
11:41:40.271 INFO - Didn’t find Let’s Encrypt certificates.
11:41:40.271 INFO - Automatic certificate generation is turned ON.
11:41:40.271 INFO - Using native openSSL provider.
11:41:40.271 WARN - ATTENTION. Server certificate paths (cert : ‘/home/michael/Documents/Blynk-server/./server_embedded.crt’, key : ‘/home/michael/Documents/Blynk-server/./server_embedded.pem’) not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
11:41:40.735 DEBUG- hard.socket.idle.timeout = 10
11:41:40.762 INFO - HTTP API and WebSockets server listening at 8080 port.
11:41:40.768 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
11:41:40.768 INFO - Mqtt hardware server listening at 8440 port.
11:43:04.443 DEBUG- Unsecured connection attempt or not supported protocol. Channel : /10.0.0.236:36446. Reason : javax.net.ssl.SSLHandshakeException: error:10000412:SSL routines:OPENSSL_internal:SSLV3_ALERT_BAD_CERTIFICATE
11:43:13.889 DEBUG- POST : /admin/login
11:43:24.554 DEBUG- POST : /admin/login
I guess that means it didn’t work then?
Maybe time to order a Raspberry Pi?
I have 3 rpi computers but I had hoped to use a better computer.
I have been able to get it to work on Windows 10 and on other versions of Linux. I am not quite ready to give up but am having little to give me hope.
Maybe try a re-install then?
Have you checked that all the paths referred to in your server.properties do actually exist, and that they have the appropriate read/write permissions?
The file paths?
I have not checked each path. I had expected it to install correctly. I will look.
Do you have a quick list of paths?
Where should I find the /admin folder?
Should it be in the root of the computer or the root of the server folder?
I meant the paths in your server.properties like these…
I don’t see a file or folder named admin.
I deleted the user file and let it recreate it and it now lets me login. Thanks for the help.
please mark as solved
Yay!
