I tried this code to show the temp at blynk but I does not work, I am using serial USB not ESP8266
Where is the problem?
Code
char auth[] = "e5047224d2a043ac831f1cb98fb87361";
const int sensor=0;//variable to anloge A0 parameter
float tempC; //variable to store temperature in degree Celsius
float vout; //variable to convert analoge read from scale of 0-1023 to scale of 0-5
pinMode(sensor,INPUT);
timer.setInterval( 1000L , sendUptime);
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
void sendUptime()
Blynk.virtualWrite(10, tempC);// sends tempC to Blynk server
vout=analogRead(sensor);
vout=(vout*500)/1023;//convert analoge read from scale of 0-1023 to scale of 0-5
tempC = vout - 2.5; //correction
Serial.print("Temprature = ");
Serial.print(tempC);// to view the temp value on the serial monitor
Serial.print(" C");
Serial.println();
