Light sensor with nodemcu
Hello Blynk friends. Im trying to make a light sensor for my home so i can check if the lights in a room are on or off. The sensor im using is " Photosensitive Sensor Module" picture https://i.imgur.com/W15cXux.png with a nodemcu board. Sinds im new to blynk and coding this is giving me some problems, I want to send the text “lights are On” or “Lights are Off” to a labled value on the blynk app. Can anyone please tell me what part of my code is not correct … remember im new to this code must be terrible i know …
char auth[] = "xxxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
const int ledPin = 5;
const int ldrPin = A0;
void myTimerEvent()
  Blynk.virtualWrite(V7, millis() / 1000); // write to the Blynk app display every second via virtual pin 1
pinMode(ledPin, OUTPUT);
pinMode(ldrPin, INPUT);
    int ldrStatus = analogRead(ldrPin);
if (ldrStatus <=300) {
digitalWrite(ledPin, HIGH);
Serial.print(ldrStatus);
Serial.println("Lights are on");
else {
digitalWrite(ledPin, LOW);
Serial.println("Lights are off");
The module in the picture does not appear to an analog output, only a digital one. There appears to be a variable resistor, that most likely adjusts when the digital output goes active. You will need to determine if the digital output goes High or Low when the light level (set with variable resistor) is exceeded. Once you know that you can then code accordingly. You also need to put the stuff in the loop() inside the timed event. See below as an example, but some adjustments may be needed.
const int ledPin = 5; //GPIO 5, D1
const int ldrPin = 4; //GPIO 4, D2
void myTimerEvent()
  int ldrStatus = digitalRead(ldrPin);
if (ldrStatus == LOW) {
 Blynk.virtualWrite(V5, "Lights are on"); //Labeled value display on pin V5
else {
Blynk.virtualWrite(V5, "Lights are off"); //Labeled value display on pin V5
Thank you! I will give it a try
A post was merged into an existing topic: I want to add light sensors to my geenhouse project. Use Nodemcu’s digital pins
