Light relay turn on with sunset and turn off with sunrise
Hello All
I found this sketch in the sketch builder i am trying to configure it to work with relay output but no luck.
I know how to get a virtual pin to activate a digital output but in this example i failed.
can anyone tell me how to do it here on V1 ?
thanks.
Social networks:            http://www.fb.com/blynkapp
                            http://twitter.com/blynk_app
  App project setup:
Time Input widget on V1.
#include <Ethernet.h>
#define W5100_CS  10
#define SDCARD_CS 4
BLYNK_WRITE(V1) {
  TimeInputParam t(param);
  // Process start time
  if (t.hasStartTime())
Serial.println(String("Start: ") +
               t.getStartHour() + ":" +
               t.getStartMinute() + ":" +
               t.getStartSecond());
  else if (t.isStartSunrise())
Serial.println("Start at sunrise");
  else if (t.isStartSunset())
Serial.println("Start at sunset");
// Do nothing
  // Process stop time
  if (t.hasStopTime())
Serial.println(String("Stop: ") +
               t.getStopHour() + ":" +
               t.getStopMinute() + ":" +
               t.getStopSecond());
  else if (t.isStopSunrise())
Serial.println("Stop at sunrise");
  else if (t.isStopSunset())
Serial.println("Stop at sunset");
// Do nothing: no stop time was set
  // Process timezone
  // Timezone is already added to start/stop time
  Serial.println(String("Time zone: ") + t.getTZ());
  // Get timezone offset (in seconds)
  Serial.println(String("Time zone offset: ") + t.getTZ_Offset());
  // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
  for (int i = 1; i <= 7; i++) {
if (t.isWeekdaySelected(i)) {
  Serial.println(String("Day ") + i + " is selected");
  Serial.println();
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  Blynk.begin(auth);
  //Blynk.begin(auth, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
why i can’t get V1 work with this code
   BLYNK_WRITE(Vx)  // Runs every-time switch widget is toggled.
      switchState = param.asInt();  // Get switch value.
      if (switchState == HIGH) {
        digitalWrite(digitalPin, HIGH);  // set digital pin HIGH
        digitalWrite(digitalPin, LOW);  // set digital pin LOW
Because there is no pin named Vx.
BLYNK_WRITE(V1) would be correct.
I’m assuming you just copy pasted that code from your sketch.
@Ze_Pico you will need to locate an Arduino sunrise / sunset library or API for Blynk Webhook to actually control anything at sunset / sunrise. TimeInput widget simply checks if you have selected the option in the app, no more, no less.
So the process is:
Was sunrise / sunset selected in the app?
If yes, is it sunrise / sunset time now (from library / API) then take some action.
No, of course not.
I need you to try the sketch and tell me if you get it working with an output.
you are correct, but i don’t know how to continue with the sketch
@Costas here is the serial print for V1 from the sketch
[5001] Connecting to 192.168.0.139
[5282] Ready (ping: 12ms).
Start at sunset
Stop at sunrise
Time zone: Europe/Paris
Time zone offset: 3600
Day 1 is selected
Day 2 is selected
Day 3 is selected
Day 4 is selected
Day 5 is selected
Day 6 is selected
Day 7 is selected
@Costas that’s the expected output from V1. Just add “control” now.
Try Timer Widget for this instead and manually set the time in the app.
Ie stop and stop time.
Start at around sunset at 8pm and finish around sunrise at 6am.
The Timer Widget simply sends a 1 or 0 depending if it is active or not.
Simple as!
if you can help me with the control it will be great.
Timer Widget is the easiest way but you need to change the start and stop time every now and then.
for the time being i am using IFTTT sending sunrise and sunset time from a WEMO switch to my hardware.
You mean sunrise / sunset control or control generally?
sunrise / sunset control using Time Input widget on V1.
I got it from the http://examples.blynk.cc/
thanks
@Ze_Pico look through this thread for sketches that actually control hardware with Time Input.
Watch for Blynk days being different to regular time library days and look up the library hack to set TimeInput as “off” when no days are selected.
Then just do the same for sunrise / sunset.
Just an FYI @Costas, links aren’t color coded for phones, could be a bit hard for some to understand :slight_smile:
@Ze_Pico see my image if you missed it
Recently I have noticed that both links and now @mentions are monochromatic as well, even on Chrome PC browser… really adds to the fun :wink:
I think I will go back to posting links in full like this Timezone conversion for the Time Input widget rather than invisible links like this.
The links are still not hightlighted in Chrome or on Smartphones but at least when Blynkers see the http://… it gives a strong indication that there is something to click on.
Nice to see the SKETCH BUILDER link at the top of each forum page.
@Pavlo please fix.
Fixed
Highlighted link test.
Doesn’t look very fixed to me @Pavlo
