Hello There,
I wanted to control a Led Widget with a Button Widget over Virtual Pins. To turn on the Led, there’s no problem. But if I want to turn off the Led nothing happens.
In the code the “led2.on” command is colored orange but the “led2.off” isn’t…
What do I do wrong?
Here’s the code for the Led:
Proper way to format posted code as per the instructions… (I already fixed your post)
As for your question… your code works fine… although you do not need the button to be 255 just to toggle the LED ON as you are using a different process then sending an intensity value.
As for the “colouring” double check your spelling and syntax in the actual code.
Thanks for the very fast reply.
I took your advice and checked the code like 70 times but I just cand find the error…
I’ll post the whole code so maybe you see the error…
Ps.: Thx for the tutorial to post a proper code ;D
The BLYNK_WRITE(V0) and (V1) are for a Joystick. This part should not bother the Led…
char auth[] = "xxx";
char ssid[] = "yyy";
char pass[] = "zzz";
BLYNK_WRITE(V0)
int pinValue = param.asInt();
if(pinValue < 250){
digitalWrite(D3, HIGH);
else{ digitalWrite(D3, LOW);
if(pinValue > 750){
digitalWrite(D2, HIGH);
else{digitalWrite(D2, LOW);
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
if(pinValue < 250){
digitalWrite(D6, HIGH);
else{
digitalWrite(D6, LOW);
if(pinValue > 750){
digitalWrite(D5, HIGH);
else{
digitalWrite(D5, LOW);
WidgetLED led2(V2);
BLYNK_WRITE(V4){
if(pinValue == 1){
led2.on();
if(pinValue == 0){
led2.off();
I glanced at it, but don’t see any glaring issues. But a few pointers…
You code is scattered all over
You are declaring your LED mid code, not up in pre setup()
You are declaring a BlynkTimer, but not using any timers anywhere??
All of your variables are local, and using the same name pinValue… probably not a big issue, but better if declared globally so you can share data outside of a function (if necessary).
So now I have optimized it but it won’t work now either… Somewhere has to be an error… The Color of the led2.off() is still not orange wich is probably the reason it won’t work… Do you see this error? Could you show me your whole code for the problem so I can compare it to mine and maybe find the error please
The code:
WidgetLED led2(V2);
BLYNK_WRITE(V0)
int pinValueV0 = param.asInt();
if(pinValueV0 < 250){
else{
if(pinValueV0 > 750){
else{
BLYNK_WRITE(V1)
int pinValueV1 = param.asInt();
if(pinValueV1 < 250){
else{
if(pinValueV1 > 750){
else{
BLYNK_WRITE(V4){
int pinValueV4 = param.asInt();
if(pinValueV4 == 1){
led2.on();
if(pinValueV4 == 0){
led2.off();
hi,do you know how to make the same thing but when it reads sensor value it turns off not by pressing it, if that even possible. like the led but only when turning it off
