I’m having trouble with my project. I use ACS712 and NodeMCU ESP8266 for my project, but how do I make the 16x2 LCD display LOAD OFF when the AC voltage is below 10 Watts, and LOAD ON when the voltage is above 10 Watt. thank you
here is my code.
@kotak please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
