I’m sorry for so much tries, but it seems that we have finally found the cause of your issue, and it’s quite strange, if I’m not to say that it is very strange. Your Android device fails to parse negative floats from strings - I’ll research for workarounds.
Strange. What Locale is setuped on your device, maybe it’s an issue of “-” symbol in string numbers.
I’ve updated build by the same link with possible workaround - try to remove current installation and try it to install again, you could send log again if it will fail.
The latest version does not have an email-link, but the problem is the same.
Yes, this issue may have something to do with Norwegian letters and symbols. The other user on this thread who has the same problem is also from Norway.
