Joystick Configuration on Blynk Web dashboard
Hi;
I just want to know how to configure Web dashboard for joystick function. I had a working sketch but I cannot configure data streams on Web dashboard.
Thanks.
For example how do I configure web dashboard for this ?
  You can receive x and y coords for joystick movement within App.
  App project setup:
    Two Axis Joystick on V1 in MERGE output mode.
    MERGE mode means device will receive both x and y within 1 message
#define BLYNK_TEMPLATE_ID           "TMPLnO4kHMJT"
#define BLYNK_DEVICE_NAME           "Test"
#define BLYNK_AUTH_TOKEN            "RcrZDIL2MZ3KoyK76CIDGIAtmDiW3_Jv"
char pass[] = "YourPassword";
BLYNK_WRITE(V1) {
  int x = param[0].asInt();
  int y = param[1].asInt();
  // Do something with x and y
  Serial.print("X = ");
  Serial.print(x);
  Serial.print("; Y = ");
  Serial.println(y);
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
Please edit your post and add triple backticks ( ``` ) before and after your whole sketch.
There is no joystick widget in the web dashboard.
So how else can I do it? I need to write 2 parameters in my function.
Are you asking about the datastream configuration ?
Yes. To write two values x and y to one datastream. For example V1 in above example.
It should be a string type datastream, check this out
Thank you. I will try this and let you know. BTW
How do you convert string to x and y? The string value comes between 0 to 225…
Just read the topic and you will understand how it works.
Thanks.
Thank you so much for the prompt replies. It works fine. :heart:
