Hello Everybody,
I need you help,
I want to use joystick in my project.
But I dont know how to add virtual pin which can be used on joystick on MERGE mode.
Code for joystick on merge mode I found in the internet but configure joystick was made in old BLYNK app.
BLYNK_WRITE(V3) {
int x = param[0].asInt();
int y = param[1].asInt();
// x = -10..-2 -1 0 1 2 ..10
// Y = -10..-2 -1 0 1 2 ..10
if ((x == 0) && (y == 0)) // stop
motorSpeed(0, LOW, LOW, 0, LOW, LOW);
please help how to add virtual button for joystick on merge mode
John93
October 30, 2021, 10:44am
2
Create a datastream and set the data type to string.
Now it is found but I can not send signal to
John93
October 30, 2021, 11:02am
4
Try this:
BLYNK_WRITE(V3)
int value = param.asInt(); // Get value as integer
// The param can contain multiple values, in such case:
Have you tried adding serial prints after these lines of code, to see what values (if any) you are getting for x
and y
Pete?
John93
October 30, 2021, 11:28am
7
@PeteKnight I assigned the joystick widget and a labeled value widget to the same vpin and I got this
Very good Idea.
Serial.print(x);
Serial.print(" - ");
Serial.println(y);
I think range is
for x= 0-255
for y=0-255
middle is 128 for both
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP32
[240] --------------------------
[243] Product: machine2
[246] Hardware: 1.0.0
[248] Firmware: 0.1.0 (build Oct 30 2021 16:55:34)
[252] Token: ...KsaZ
[254] Device: ESP32 @ 240MHz
[257] MAC: 7C:9E:BD:61:40:CC
[260] Flash: 4096K
[262] ESP sdk: v3.3.5-1-g85c43024c
[265] Chip rev: 1
[267] Free mem: 277136
[269] --------------------------
[272] INIT => CONNECTING_NET
[275] Connecting to WiFi: UGE_MAX
[2568] Using Dynamic IP: 192.168.41.66
[2568] CONNECTING_NET => CONNECTING_CLOUD
[2578] Connecting to blynk.cloud:443
[4819] Certificate OK
[5133] Ready (ping: 312ms).
[5269] CONNECTING_CLOUD => RUNNING
DEVICE OFF
128 - 128
128 - 101
128 - 232
128 - 255
129 - 255
130 - 255
131 - 255
132 - 255
128 - 128
141 - 88
253 - 122
255 - 125
255 - 126
255 - 125
255 - 124
128 - 128
87 - 82
3 - 100
1 - 109
1 - 116
0 - 117
0 - 118
0 - 119
0 - 120
0 - 122
0 - 124
1 - 111
16 - 66
27 - 49
35 - 39
36 - 39
35 - 40
36 - 39
40 - 34
46 - 30
51 - 25
57 - 21
64 - 17
84 - 8
98 - 4
103 - 2
115 - 1
121 - 0
129 - 0
130 - 0
131 - 0
132 - 0
133 - 0
134 - 0
135 - 0
136 - 0
137 - 0
138 - 0
139 - 1
128 - 128
How can I make range for x and y like this
x = from -10 to 10
y = from -10 to 10
thank you guys you helped me to solve my problem
