Hi mates, I’m struggling with my ooooold Rpi 1 model B+ with the java 10 installation.
At the moment my Orange Pi will remain the java 8 stuff.
Can somebody show me the answer of the console when you click “java -version”, please?
Hi @marvin7,@Gunner,
Could you please be so kind to have a look and advise? This is the my console:
pi@raspberrypi:~ $ sudo apt install ./bellsoft-jdk10.0.1-linux-arm32-vfp-hflt.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'bellsoft-java10' instead of './bellsoft-jdk10.0.1-linux-arm32-vfp-hflt.deb'
The following NEW packages will be installed:
bellsoft-java10
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/220 MB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 /home/pi/bellsoft-jdk10.0.1-linux-arm32-vfp-hflt.deb bellsoft-java10 armhf 10.0.1 [220 MB]
Selecting previously unselected package bellsoft-java10.
(Reading database ... 124722 files and directories currently installed.)
Preparing to unpack .../bellsoft-jdk10.0.1-linux-arm32-vfp-hflt.deb ...
Unpacking bellsoft-java10 (10.0.1) ...
Setting up bellsoft-java10 (10.0.1) ...
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/appletviewer to provide /usr/bin/appletviewer (appletviewer) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jar to provide /usr/bin/jar (jar) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/java to provide /usr/bin/java (java) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/javadoc to provide /usr/bin/javadoc (javadoc) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/javap to provide /usr/bin/javap (javap) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jconsole to provide /usr/bin/jconsole (jconsole) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jdeprscan to provide /usr/bin/jdeprscan (jdeprscan) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jhsdb to provide /usr/bin/jhsdb (jhsdb) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jinfo to provide /usr/bin/jinfo (jinfo) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jlink to provide /usr/bin/jlink (jlink) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jmod to provide /usr/bin/jmod (jmod) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jrunscript to provide /usr/bin/jrunscript (jrunscript) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jstack to provide /usr/bin/jstack (jstack) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jstatd to provide /usr/bin/jstatd (jstatd) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/orbd to provide /usr/bin/orbd (orbd) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/rmid to provide /usr/bin/rmid (rmid) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/schemagen to provide /usr/bin/schemagen (schemagen) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/servertool to provide /usr/bin/servertool (servertool) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/unpack200 to provide /usr/bin/unpack200 (unpack200) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/wsimport to provide /usr/bin/wsimport (wsimport) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/idlj to provide /usr/bin/idlj (idlj) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jarsigner to provide /usr/bin/jarsigner (jarsigner) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/javac to provide /usr/bin/javac (javac) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jcmd to provide /usr/bin/jcmd (jcmd) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jdb to provide /usr/bin/jdb (jdb) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jdeps to provide /usr/bin/jdeps (jdeps) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jimage to provide /usr/bin/jimage (jimage) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jjs to provide /usr/bin/jjs (jjs) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jmap to provide /usr/bin/jmap (jmap) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jps to provide /usr/bin/jps (jps) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jshell to provide /usr/bin/jshell (jshell) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/jstat to provide /usr/bin/jstat (jstat) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/keytool to provide /usr/bin/keytool (keytool) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/pack200 to provide /usr/bin/pack200 (pack200) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/rmic to provide /usr/bin/rmic (rmic) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/rmiregistry to provide /usr/bin/rmiregistry (rmiregistry) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/serialver to provide /usr/bin/serialver (serialver) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/tnameserv to provide /usr/bin/tnameserv (tnameserv) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/wsgen to provide /usr/bin/wsgen (wsgen) in auto mode
update-alternatives: using /usr/lib/jvm/jdk-10-bellsoft-arm32-vfp-hflt/bin/xjc to provide /usr/bin/xjc (xjc) in auto mode
pi@raspberrypi:~ $ java -jar server-0.36.0.jar -dataFolder /home/pi/Blynk &
[1] 1254
pi@raspberrypi:~ $ java -version
[1]+ Illegal instruction java -jar server-0.36.0.jar -dataFolder /home/pi/Blynk
Illegal instruction
pi@raspberrypi:~ $ java --version
Illegal instruction
Thanks in advance!!
can you do:
which java
and post the output?
I think something is screwed up with your java versions., try this from the dir where you downloaded the deb
sudo dpkg --force-all -i ./bellsoft-jre10.0.1-linux-arm32-vfp-hflt.deb
It does something but at the end the result is the same:
pi@raspberrypi:~ $ sudo dpkg --force-all -i ./bellsoft-jre10.0.1-linux-arm32-vfp-hflt.deb
Selecting previously unselected package bellsoft-java10-runtime.
(Reading database ... 125404 files and directories currently installed.)
Preparing to unpack .../bellsoft-jre10.0.1-linux-arm32-vfp-hflt.deb ...
Unpacking bellsoft-java10-runtime (10.0.1) ...
Setting up bellsoft-java10-runtime (10.0.1) ...
[1] 1410
pi@raspberrypi:~ $ which java
/usr/bin/java
pi@raspberrypi:~ $
Ok, I think it’s a 32b / 64b issue now. That would only explain that in both commands it goes wrong.
Mmmm…To be honest I have no idea about it…Linux is out of my control…
The best I can do is to stay with Java 8 at the moment…
Many thanks for your time @Lichtsignaal, much appreciated!!
Kind regards!
Np, I’m now quite sure it has to do with 32bit vs 64bit java runtimes…
Anyway, I can always have a look using teamviewer of direct SSH access to your Pi. Just let me know
My Pi is yours…
Let me know by PM what you need to access here and I’ll do my best
Thanks!!!
For shts and giggles: Liberica doesn’t work on Pi B+ CPU’s (e.g. ARMv6). It only works on v7 and higher
to akurat zakończyło się raczej jako no no no …
I’m just going to wait for java8 fix.
According to this comment on @scargill’s blog, it is possible to get email working with Java10.
@PeteKnight Thanks for pointing it out. I might look into that option on my Java10 test server. Meanwhile I shall enjoy NOT being “stubbornly forced” away from server-0.36.1-java8.jar (which I am currently running). It always amazes me how some demand so much from a “free” service
EDIT - I don’t see anything special about the install script, I already did all the same stuff very easily “manually” so to speak… so if email works for the user (and it is not clarified that it does work), then I don’t see how he did it.
I suspect it might have to do with the certificates method?? I used openssl, but might eventually look into the other options… but not critical as Java8 works just fine.
@Gunner have you noticed slightly higher latency since moving to Java 10?
I’ve rolled back my Pi 2 to Java 8 because there was often a noticeable delay between the button press and when my lights came on. All seems fine with 0.36.1 running on Java 8 now…
Can’t say that I noticed any latency issues and I was running NodeJS and Python clients as well… but then I was using the RPi3.
But same as you, I am just sticking with Java8 for my main server.
