gunner@RPi3:/ $ apt list --installed | grep jdk
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
oracle-java8-jdk/stable,now 8u65 armhf [installed]
gunner@RPi3:/ $
No mention of the version 10 install??
gunner@RPi3:/ $
A (freaking) Linux World Ehh…
What happens if you search for jre
instead?
Nothing
gunner@RPi3:/ $ apt list --installed | grep jre
gunner@RPi3:/ $
But this finally gets me something
gunner@RPi3:/ $ apt list --installed | grep bellsoft
bellsoft-java10/now 10.0.1 armhf [installed,local]
gunner@RPi3:/ $
err… nope… ARRRGGGG
gunner@RPi3:/ $ sudo apt-get --purge remove bellsoft-java10/now 10.0.1 armhf
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package 10.0.1
E: Couldn't find any package by glob '10.0.1'
E: Couldn't find any package by regex '10.0.1'
E: Unable to locate package armhf
gunner@RPi3:/ $
only this!
Who names java JDK/JRE package like this?? Who they are?
Finally!!!
gunner@RPi3:/ $ sudo apt-get --purge remove bellsoft*
Note, selecting 'bellsoft-java10' for glob 'bellsoft*'
The following packages will be REMOVED:
bellsoft-java10*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Sorry, didn’t know that Bellsoft had its own version - my bad!
Perhaps this one is better to list installed packages:
# dpkg --get-selections | grep -v deinstall
As I said from the beginning, wrong package name!
Hah… you so smrt… tell me why the darn email not working
Actualy, just installing the jre version now… so we will see…
Nope… oh well…
17:37:11.826 ERROR- Error sending email auth token to user : xxxxxxxxxx@gmail.com. Error: Could not convert socket to TLS
So… am I the only one, or has other Bellsoft Java 10 users run into this? No sense in promoting it for this OP if it doesn’t allow this somewhat critical function.
Have you tried searching for this specific error?? I’s java, not Blynk related as pointed by @Dmitriy. Some results shows, but currently I’m far from being interested…
Yep… basically been my whole task for the last day or so… lots of references with older versions… all pointing to needing the same commands we already have in the mail.properties
file.
@Dmitriy has suspicions… but until we get regular Java-8/multi-version server files or confirmed Blynk/not-Blynk, then I am still pursuing it as it otherwise (email aside) allows Java10 Server to work with RPi… which is this OPs question
I’m trying to stay away from software with even version numbers Think we have to wait for Dmitriy on this…
Please, just wait fro java8 release. No need to hurry. New release has only 1 bug fix, so this is not big deal.
Memory consumption could be optimized, as well as CPU consumption, but you know - no time .
It doesn’t email at all. No idea why. I made mail.properties and it inits Gmail transport, so that all looks ok. It doesn’t email me from my existing Java8 (true Oracle) also not anymore.
Getting this:
ERROR- Error sending email auth token to user : blynk@domain.com. Error: Could not convert socket to TLS
Sounds like it overwrote something… Well since it is probably not Blynk specific, we might have to just await the Java8 releases… it sounds like they are not completely going away, like I first feared.
I haven’t overwritten anything, I just setup a testing Pi2 (my production runs on Pi3).
Yes yes…
Okay so I just installed Java 10 as per this guide and can run the 0.36.0 on my Rpi2.
I’m now in the same boat as @Lichtsignaal and can’t send emails
