Partially true
I think I am using the correct commands… but while it “sees it” for version check, it will not remove it?
gunner@RPi3:/ $ java --version
openjdk 10.0.1-BellSoft 2018-04-17
OpenJDK Runtime Environment (build 10.0.1-BellSoft+0)
OpenJDK Server VM (build 10.0.1-BellSoft+0, mixed mode)
gunner@RPi3:/ $ sudo apt-get --purge remove openjdk
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package openjdk
gunner@RPi3:/ $ sudo apt-get --purge remove openjdk 10.0.1-BellSoft 2018-04-17
E: Unable to locate package 10.0.1-BellSoft
E: Couldn't find any package by glob '10.0.1-BellSoft'
E: Couldn't find any package by regex '10.0.1-BellSoft'
E: Unable to locate package 2018-04-17
gunner@RPi3:/ $ sudo apt-get --purge remove openjdk*
Note, selecting 'openjdk-9-jre-headless' for glob 'openjdk*'
Note, selecting 'openjdk-8-jdk' for glob 'openjdk*'
Note, selecting 'openjdk-8-jre' for glob 'openjdk*'
Note, selecting 'openjdk-6-jdk' for glob 'openjdk*'
Note, selecting 'openjdk-6-jre' for glob 'openjdk*'
Note, selecting 'openjdk-9-demo' for glob 'openjdk*'
Note, selecting 'openjdk-6-jre-headless' for glob 'openjdk*'
Note, selecting 'openjdk-8-demo' for glob 'openjdk*'
Note, selecting 'openjdk-8-jdk-headless' for glob 'openjdk*'
Note, selecting 'openjdk-9-dbg' for glob 'openjdk*'
Note, selecting 'openjdk-7-jre-headless' for glob 'openjdk*'
Note, selecting 'openjdk-9-doc' for glob 'openjdk*'
Note, selecting 'openjdk-8-jre-zero' for glob 'openjdk*'
Note, selecting 'openjdk-8-source' for glob 'openjdk*'
Note, selecting 'openjdk-jre' for glob 'openjdk*'
Note, selecting 'openjdk-9-jdk' for glob 'openjdk*'
Note, selecting 'openjdk-9-jre' for glob 'openjdk*'
Note, selecting 'openjdk-7-jdk' for glob 'openjdk*'
Note, selecting 'openjdk-7-jre' for glob 'openjdk*'
Note, selecting 'openjdk-9-jdk-headless' for glob 'openjdk*'
Note, selecting 'openjdk-8-jre-headless' for glob 'openjdk*'
Note, selecting 'openjdk-9-source' for glob 'openjdk*'
Note, selecting 'openjdk-8-dbg' for glob 'openjdk*'
Note, selecting 'openjdk-8-doc' for glob 'openjdk*'
Package 'openjdk-7-jre' is not installed, so not removed
Package 'openjdk-6-jre' is not installed, so not removed
Package 'openjdk-7-jre-headless' is not installed, so not removed
Package 'openjdk-6-jre-headless' is not installed, so not removed
Package 'openjdk-7-jdk' is not installed, so not removed
Package 'openjdk-jre' is not installed, so not removed
Package 'openjdk-6-jdk' is not installed, so not removed
Package 'openjdk-8-dbg' is not installed, so not removed
Package 'openjdk-8-demo' is not installed, so not removed
Package 'openjdk-8-doc' is not installed, so not removed
Package 'openjdk-8-jdk' is not installed, so not removed
Package 'openjdk-8-jdk-headless' is not installed, so not removed
Package 'openjdk-8-jre' is not installed, so not removed
Package 'openjdk-8-jre-headless' is not installed, so not removed
Package 'openjdk-8-jre-zero' is not installed, so not removed
Package 'openjdk-8-source' is not installed, so not removed
Package 'openjdk-9-dbg' is not installed, so not removed
Package 'openjdk-9-demo' is not installed, so not removed
Package 'openjdk-9-doc' is not installed, so not removed
Package 'openjdk-9-jdk' is not installed, so not removed
Package 'openjdk-9-jdk-headless' is not installed, so not removed
Package 'openjdk-9-jre' is not installed, so not removed
Package 'openjdk-9-jre-headless' is not installed, so not removed
Package 'openjdk-9-source' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
gunner@RPi3:/ $
