How can the following code be merged for showing data on BLYNK.
Or anyone having code for both of them.
HeartRate;
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
Serial.println("Initializing...");
// Initialize sensor
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println("MAX30105 was not found. Please check wiring/power. ");
while (1);
Serial.println("Place your index finger on the sensor with steady pressure.");
particleSensor.setup(); //Configure sensor with default settings
particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
long irValue = particleSensor.getIR();
if (checkForBeat(irValue) == true)
//We sensed a beat!
long delta = millis() - lastBeat;
lastBeat = millis();
beatsPerMinute = 60 / (delta / 1000.0);
if (beatsPerMinute < 255 && beatsPerMinute > 20)
rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
rateSpot %= RATE_SIZE; //Wrap variable
//Take average of readings
beatAvg = 0;
for (byte x = 0 ; x < RATE_SIZE ; x++)
beatAvg += rates[x];
beatAvg /= RATE_SIZE;
Serial.print("IR=");
Serial.print(irValue);
Serial.print(", BPM=");
Serial.print(beatsPerMinute);
Serial.print(", Avg BPM=");
Serial.print(beatAvg);
if (irValue < 50000)
Serial.print(" No finger?");
Serial.println();
blood O2;
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include "MAX30105.h" //sparkfun MAX3010X library
char auth[] = "fIGPsYeI0rf2DWG6FAPXdf-NGuhaF0Fe";
char ssid[] = "vivo 1713";
char pass[] = "fab123456";
#define INTERVAL_MESSAGE2 60000
unsigned long time_2 = 0;
int period = 2000;
unsigned long time_now = 0;
double avered = 0;
double aveir = 0;
double sumirrms = 0;
double sumredrms = 0;
int i = 0;
int Num = 100; //calculate SpO2 by this sampling interval
int oxygen;
double ESpO2 = 95.0; //initial value of estimated SpO2
double FSpO2 = 0.7; //filter factor for estimated SpO2
double frate = 0.95; //low pass filter for IR/red LED value to eliminate AC component
#define TIMETOBOOT 3000 // wait for this time(msec) to output SpO2
#define SCALE 88.0 //adjust to display heart beat and SpO2 in the same scale
#define SAMPLING 5 //if you want to see heart beat more precisely , set SAMPLING to 1
#define FINGER_ON 3000 // if red signal is lower than this , it indicates your finger is not on the sensor
#define MINIMUM_SPO2 0.0
byte rateSpot = 0;
int beatAvg;
#define USEFIFO
while (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println("MAX30102 was not found. Please check wiring/power/solder jumper at MH-ET LIVE MAX30102 board. ");
//while (1);
//Setup to sense a nice looking saw tooth on the plotter
byte ledBrightness = 255; // 0x7F Options: 0=Off to 255=50mA
byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
int sampleRate = 400; //1000 is best but needs processing power//Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 16384; //Options: 2048, 4096, 8192, 16384
// Set up the wanted parameters
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
particleSensor.enableDIETEMPRDY();
timer.setInterval(500, sendUptime);
void sendUptime()
Blynk.virtualWrite(V4, oxygen);
Blynk.virtualWrite(V5, beatAvg);
uint32_t ir, red, green;
double fred, fir;
double SpO2 = 0; //raw SpO2 before low pass filtered
#ifdef USEFIFO
particleSensor.check(); //Check the sensor, read up to 3 samples
while (particleSensor.available())
{ //do we have new data
#ifdef MAX30105
red = particleSensor.getFIFORed(); //Sparkfun's MAX30105
ir = particleSensor.getFIFOIR(); //Sparkfun's MAX30105
#else
red = particleSensor.getFIFOIR(); //why getFOFOIR output Red data by MAX30102 on MH-ET LIVE breakout board
ir = particleSensor.getFIFORed(); //why getFIFORed output IR data by MAX30102 on MH-ET LIVE breakout board
#endif
i++;
fred = (double)red;
fir = (double)ir;
avered = avered * frate + (double)red * (1.0 - frate); //average red level by low pass filter
aveir = aveir * frate + (double)ir * (1.0 - frate); //average IR level by low pass filter
sumredrms += (fred - avered) * (fred - avered); //square sum of alternate component of red level
sumirrms += (fir - aveir) * (fir - aveir); //square sum of alternate component of IR level
if ((i % SAMPLING) == 0)
{ //slow down graph plotting speed for arduino Serial plotter by thin out
if (millis() > TIMETOBOOT)
if (ir < FINGER_ON)
ESpO2 = MINIMUM_SPO2; //indicator for finger detached
float temperature = particleSensor.readTemperatureF();
if (ESpO2 <= -1)
ESpO2 = 0;
if (ESpO2 > 100)
ESpO2 = 100;
oxygen = ESpO2;
Serial.print(" Oxygen % = ");
Serial.println(oxygen);
if ((i % Num) == 0)
double R = (sqrt(sumredrms) / avered) / (sqrt(sumirrms) / aveir);
// Serial.println(R);
SpO2 = -23.3 * (R - 0.4) + 100; //http://ww1.microchip.com/downloads/jp/AppNotes/00001525B_JP.pdf
ESpO2 = FSpO2 * ESpO2 + (1.0 - FSpO2) * SpO2; //low pass filter
//Serial.print(SpO2); Serial.print(","); Serial.println(ESpO2);
sumredrms = 0.0;
sumirrms = 0.0;
i = 0;
break;
particleSensor.nextSample(); //We're finished with this sample so move to next sample
//Serial.println(SpO2);
Serial.println(irValue);
if (millis() > time_2 + INTERVAL_MESSAGE2 && oxygen < 93)
time_2 = millis();
Blynk.notify("Alert! Oxygen Saturation below 93% Detected");
Serial.print("Alert called");
#endif
