Issue on new blynk,
I tried this coding on old blynk and it works well, but when jump into new blynk the control cannot operate.
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
const byte led= 2;
  #include <WiFi.h>
  #include <WiFiClient.h>
  #include <BlynkSimpleEsp32.h>
  char ssid[] = "";
  char pass[] = "";
    pinMode(led, OUTPUT);
Do you mean that your device is online but the LED is not working, or that you’re trying to connect your device to the cloud with no success ?
yup successfully connected to the blynk, but when I push button from blynk web, led not reflected (still low) .
I guess you’re using a digital pin datastream. If that’s the case, then I highly recommend using virtual pins instead.
https://docs.blynk.io/en/blynk.edgent-firmware-api/virtual-pins
I tried the virtual pin , but still same.
Posting the updated sketch might help.
const byte led= 2;
  #include <WiFi.h>
  char ssid[] = "";
  char pass[] = "";
Check this example
For virtual pins to work, you need to have additional code that is triggered when the virtual pin is pressed.
This consists of callback functions with the name ’BLYNK_WRITE(vPin)’ where ’vPin’ is the virtual PIN number of your datastream.
Read this for more info…
thank you so much
thanks
