Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Is there a widget that allows to open other apps on the smartphone by pressing a button?
In the case of blynk, there are limitations to linking CCTV. So, I hope that customers can immediately open the CCTV APP they use.
There are so many different CCTV and linked APPs, and it is difficult for CCTV companies to open the code for internal operation anyway, so it would be better for maintenance to open the APP through a widget.
I think it will be a good opportunity for Blynk as well.
