Is Service tab disabled on Blynk console
I can’t see the service tab in the Blynk console, before for the same sketch I could see my data plotted in a graph Under that tab, but recently I uploaded another sketch to the device without timer.setinterval () but then again I reverted back to my old sketch, still can’t see the service tab.
Is it gone for all??
But now the service tab is gone
Like this
You’re right, I can’t see it as well.
TY for the response, but it is only gone for me or Blynk console has got changed?
Yes.
Now you can create your own Service tab using the new widget “Service Chart”.
Available in PRO plan.
…but on the chart only I saw the Delete icon, no Config, no Copy icon…
A second Y axis (right side)with adjustable scale should be useful.
Servicechart
@solbahia we just moved the “Service Chart” to the widgets section, as now the dashboard may have “Tabs”, you can easily add the service chart as a separate tab if needed. It has the same functionality as it had in the “Service Chart” tab. In other words - now you don’t have a “Service Chart” by default, but you can add it if your project requires it.
Yes. Service chart can work with any DS included to with it.
You can have only 1 service chart per dashboard.
Excelent, thank you @Dmytro !
