I want to avoid hard coding of my wifi SSID, pass and Blynk auth token for that I used “WiFiManager” library -> https://github.com/tzapu/WiFiManager
but I found some issues in that so I want to replace with “IotWebConf” library -> https://github.com/prampec/IotWebConf in “IotWebConf” there are some more features then “WiFiManager” check out “IotWebConf” library for your project.
can anyone make a combo of Blynk + IotWebConf for the community, and for me:wink:?
links are given
* IotWebConf08WebRelay.ino -- IotWebConf is an ESP8266/ESP32
* non blocking WiFi/AP web configuration library for Arduino.
* https://github.com/prampec/IotWebConf
* Copyright (C) 2018 Balazs Kelemen <prampec+arduino@gmail.com>
* This software may be modified and distributed under the terms
* of the MIT license. See the LICENSE file for details.
* Example: Web Relay Demo
* Description:
* All IotWebConf specific aspects of this example are described in
* previous examples, so please get familiar with IotWebConf before
* starting this example. So nothing new will be explained here,
* but a complete demo application will be built.
* It is also expected from the reader to have a basic knowledge over
* HTML to understand this code.
* This example stets up a web page, where switch action can take place.
* The repay can be also altered with the push button.
* The thing will delay actions arriving within 10 seconds.
* This example also provides the firmware update option.
* (See previous examples for more details!)
* Hardware setup for this example:
* - A Relay is attached to the D1 pin (On=HIGH)
* - An LED is attached to LED_BUILTIN pin with setup On=LOW.
* - A push button is attached to pin D2, the other leg of the
* button should be attached to GND.
#include <IotWebConf.h>
// -- Initial name of the Thing. Used e.g. as SSID of the own Access Point.
const char thingName[] = "testThing";
// -- Initial password to connect to the Thing, when it creates an own Access Point.
const char wifiInitialApPassword[] = "smrtTHNG8266";
#define STRING_LEN 128
// -- Configuration specific key. The value should be modified if config structure was changed.
#define CONFIG_VERSION "web1"
// -- When BUTTON_PIN is pulled to ground on startup, the Thing will use the initial
// password to buld an AP. (E.g. in case of lost password)
#define BUTTON_PIN D2
// -- Status indicator pin.
// First it will light up (kept LOW), on Wifi connection it will blink,
// when connected to the Wifi it will turn off (kept HIGH).
#define STATUS_PIN LED_BUILTIN
// -- Connected ouput pin.
#define RELAY_PIN D1
#define ACTION_FEQ_LIMIT 10000
#define NO_ACTION -1
// -- Callback method declarations.
void configSaved();
DNSServer dnsServer;
WebServer server(80);
HTTPUpdateServer httpUpdater;
IotWebConf iotWebConf(thingName, &dnsServer, &server, wifiInitialApPassword, CONFIG_VERSION);
boolean needReset = false;
int needAction = NO_ACTION;
int state = LOW;
unsigned long lastAction = 0;
Serial.println();
Serial.println("Starting up...");
pinMode(RELAY_PIN, OUTPUT);
iotWebConf.setStatusPin(STATUS_PIN);
iotWebConf.setConfigPin(BUTTON_PIN);
iotWebConf.setConfigSavedCallback(&configSaved);
iotWebConf.setupUpdateServer(&httpUpdater);
// -- Initializing the configuration.
iotWebConf.init();
// -- Set up required URL handlers on the web server.
server.on("/", handleRoot);
server.on("/config", []{ iotWebConf.handleConfig(); });
server.onNotFound([](){ iotWebConf.handleNotFound(); });
Serial.println("Ready.");
// -- doLoop should be called as frequently as possible.
iotWebConf.doLoop();
if (needReset)
Serial.println("Rebooting after 1 second.");
iotWebConf.delay(1000);
ESP.restart();
unsigned long now = millis();
// -- Check for button push
if ((digitalRead(BUTTON_PIN) == LOW)
&& (ACTION_FEQ_LIMIT < now - lastAction))
needAction = 1 - state; // -- Invert the state
applyAction(now);
void applyAction(unsigned long now)
if ((needAction != NO_ACTION)
state = needAction;
digitalWrite(RELAY_PIN, state);
if (state == HIGH)
iotWebConf.blink(5000, 95);
iotWebConf.blink(0, 0); // No blink
Serial.print("Switched ");
Serial.println(state == HIGH ? "ON" : "OFF");
lastAction = now;
* Handle web requests to "/" path.
void handleRoot()
// -- Let IotWebConf test and handle captive portal requests.
if (iotWebConf.handleCaptivePortal())
// -- Captive portal request were already served.
return;
if (server.hasArg("action"))
String action = server.arg("action");
if (action.equals("on"))
needAction = HIGH;
else if (action.equals("off"))
needAction = LOW;
applyAction(millis());
String s = F("<!DOCTYPE html><html lang=\"en\"><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/>");
s += FPSTR(IOTWEBCONF_HTTP_STYLE);
s += "<title>IotWebConf 08 Web Relay</title></head><body>";
s += iotWebConf.getThingName();
s += "<div>State: ";
s += (state == HIGH ? "ON" : "OFF");
s += "</div>";
s += "<div>";
s += "<button type='button' onclick=\"location.href='?action=on';\" >Turn ON</button>";
s += "<button type='button' onclick=\"location.href='?action=off';\" >Turn OFF</button>";
s += "<button type='button' onclick=\"location.href='?';\" >Refresh</button>";
s += "</div>";
s += "<div>Go to <a href='config'>configure page</a> to change values.</div>";
s += "</body></html>\n";
server.send(200, "text/html", s);
void configSaved()
Serial.println("Configuration was updated.");
needReset = true;
