Hello, I’ve successfully used WifiManager by @tzapulica to have an ESP8266 enter access point mode to get wifi credentials before running Blynk. Now I’m trying to write a sketch where the user can enter the auth code (Blynk token) as well. I have added the required parameter to my setup function, and the field for the token shows up in access point mode. When it goes to webserver mode to run, my ESP8266 is not connecting to Blynk. Here is a snippet of the code I am trying to use:
One thing I noticed in the AutoConnectWithFSParameters example, @tzapulica creates a 34 byte string for the Blynk token, but creates a 32 byte custom parameter. Is there a reason for this, is it because he’s using the following command?
hi, the example is a bit wrong, i think it should be 33 bytes in both places.
it is normal that blynk is not running when the web portal is up, as autoConnect is blocking. you are also most likely not connected to the internet at that point, so there wouldn t be much chance of blynk connecting anyway.
Thank you. I’ve tried all the examples as well as the sonoff boiler plate. I’m using (Wemos D1 Mini & have also tried the Node MCU). The WIFI network does not appear in my choices. I’m using an Iphone 6, Arduino 1.8.0 and have loaded the latest ESP8266 libraries inside the Arduino IDE. Please advise
I noticed that if you have had the nodemcu connected to the wifi when upload the sketch, the wifimanager knows that and direct connect to your wifi… that hapenned to me…
Try to switch off your router, start the nodemcu and let your iPhone to search wifi nodes, the one you have set in wifimanager autoconnect should appear, try to connect to it and after few seconds the screen to config the access point should appear.
