I’m working on a project to collect data with LabVIEW in LattePanda.
For this project, I would like to integrate the data collected by LapView into Blink.
Is it possible to upload the data collected by LabView to Blink via http API?
Or is there a better way?
(For example, passing data from labview to esp32, then passing data from esp32 to blynk, then passing data to lattepanda via ethernet communication…)
If you’re going to use APIs to write to Blynk then you should be aware that the current version of Blynk uses a different format for APIs compared to the old Legacy version.
The current API documentation is here…
Blynk Legacy could be run on the cloud servers or on a local server. The functionality (from the HTTP API point of view) was the same for both cloud and local servers. However, looking through the topics in the link I provided the majority of them refer to the Blynk Legacy cloud servers.
Yes, it’s possible to update a virtual pin/datastream using the HTTP(S) API. It’s covered in the “Update Datastream Value” section of the documentation, in the link I provided.
Thanks for the reply, I’ve done some testing and have been successful in updating VirtualPin’s data to the cloud using the HTTP API.
By any chance, is it possible to change the status to online or offline using the API?
Or do I need to add a separate event (which I don’t really want to do)?
No, the device will always appear as offline unless there’s an always-on connection established between the device and the server. As the HTTP(S) API doesn’t work in this way the device will always appear offline.
There is no event available to change the on/offline status.
It’s not about being connected to the internet, it’s about your system having negotiated an always-on connection with the Blynk server and exchanging regular heartbeat pings.
This isn’t possible when using the HTTP(S) API, only with the Blynk library - which isn’t possible with your system.
When you use the Blynk plug-in (contrib) for Blynk an always-on connection is established with the server, so the device appears online.
Whit this setup, you don’t need to use the HTTP(S) API for Blynk, as all communication to and from the Blynk server is handled by the plug-in.
The other advantage of this approach is that incoming messages from Blynk trigger the Write node in the plug-in, so you don’t have to keep constantly polling the server to look for virtual pin changes.
It’s very straightforward. You use the appropriate nodes in the plug-in to send the message payload to Blynk, or to receive data from Blynk in the form of a message payload.
Another mechanism for what? You seem to be jumping from one platform to another in your questions without any background information about what you’re trying to achieve.
I’m not sure what sort of feedback you are expecting from the forum on that, without providing lots of additional information.
That seems a lot of work just to have your Blynk device appear as “online”.
If you really want to understand the communication between a device and the Blynk server then you should probably run a C++ sketch on a device such as an ESP8266 and turn on Blynk debugging then look at the two-way communications between the device and Blynk…
