Hello GTT
Thanks for the response. I have successfully connected my system consisting of an Arduino Mega 2560 (and using a very similar program on the Arduino Uno) to Blynk via an ESP8266 WiFI module using the code i adapted from the Blynk example sketches:
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
Youâll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Mega ADK board
example.
//#define BLYNK_PRINT Serial
#include <Blynk.h>
#include <ESP8266_Lib.h>
#include <FastLED.h>
#define LED_PIN 10
#define NUM_LEDS 30
CRGB leds[NUM_LEDS];
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
//WIFI 1 Credentials
char ssid0[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
char pass0[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxx";
/WIFI 2 Credentials
char ssid1[] = "xxxxxxxxxxxxxxxxxxxxxxxx";
char pass1[] = "xxxxxxxxxxxxxxxxxxxxxxxx";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//String APlist = wifi.getAPList ();
//Serial.print ("AP List:");
//Serial.println (APlist);
Serial.println("Establishing WIFI connection with Blynk...");
//Blynk.begin(auth, wifi, ssid0, pass0); //Wifi credentials 1
Blynk.begin(auth, wifi, ssid1, pass1); //Wifi credentials 2
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
Serial.println("LED strip control with preset light settings using Blynk ");
timer1.setInterval(100L, LightSettings);
With a manual selection of credentials 1 or 2 everything works great. However i thought to improve the capability of my project by allowing the firmware to connect to whichever of the networks was available (i.e. if Wifi credentials 1 is not available on startup then check if Wifi credentials 2 is available and connect to it). Since i learned that Blynk.begin() is a blocking function (which ever credentials i used with the first Blynk.begin("credentials1") it will hung there if that network was not available did not try the next Blynk.begin(credentials2) ).
The attempted to resolve this by first trying to connect to the network using the Wifi.begin() and once i have a connection then use a Blynk.config() to establish a connection with blynk as shown in the sketch below:
#include <Blynk.h>
#include <WiFi.h>
#define LED_PIN 10
#define NUM_LEDS 30
char auth[] = "xxxxxxxxxxxxxxxxxxxxxx";
char ssid0[] = "xxxxxxxxxxxxxxxxxxx";
char pass0[] = "xxxxxxxxxxxxxxxxxx";
char ssid1[] = "xxxxxxxxxxxxxx";
char pass1[] = "xxxxxxxxxxxxxx";
char server[] = "blynk-cloud.com"; // URL for Blynk Cloud Server
int port = 8080;
WiFi.begin(ssid1, pass1); // Non-blocking if no WiFi available
delay(7000);
Blynk.config(auth, server, port);
Serial.println(WiFi.status());
while(WiFi.status()==WL_IDLE_STATUS){
Serial.print(".");
if(WiFi.status()==WL_CONNECTED){
Serial.println("Esp8266 is connected to wifi");
if (Blynk.connected()){
Serial.println("ESP8266 is connected to Blynk cellphone wifi");
else if (WiFi.status()==WL_CONNECT_FAILED){
Serial.println("Try the next available wifi");
The first challenge however is when i try to compile the sketch in the Arduino IDE, i get an error message:
âno matching function for call to âBlynkWifi::config(char [33], char [16], int&)ââ
I canât seem to figure out why i am getting this message as I have included the blynk library and it stands to reason that this function would be a part of it.
The second challenge that I am trying to resolve is that when i use the Wifi.status() function it actually does not work as expected which i assume is because i am using the esp8266 wifi module instead of an arduino shield (the result of this function is 255 which is a âWL_NO_SHIELDâ). I came across a few suggestions but after a few attempts I realized these would not work because it seems they work only for an ESP8266 controller (not an arduino paired to an Esp8266 wifi module), which was evident by the fact that the ESP8266WiFi.h library would only be recognized in the arduino IDE when the ESP8266 board was selected.
If someone can suggest a better way in which to achieve the goal-Enable the Arduino to check which my two networks are available and connect to the one detected to be available-i will be extremely grateful.
