Just post some examples to AutoReConnect to Multiple WiFi APs and Multiple Blynk Servers (local/cloud-based) in GitHub with some contribution by @Madhukesh
AutoReconnect to demonstrate the usage of WiFi and Blynk AutoReConnect feature for ESP8266, ESP32
Why do we need this AutoReconnect?
Imagine you have a system with mission-semi-critical functions, measuring water level and control the sump pump or doing something much more important using extensive GUI, such as medical equipments, security and/or fire-smoke alarm, etc. You normally use a software timer to poll, or even place the function in loop(). But what if another function is blocking the loop() or setup().
So your function might not be executed, and the result would be disastrous.
You’d prefer to have your function called, no matter what happening with other functions (busy loop, bug, etc.).
The best choice is to use a Hardware Timer with Interrupt in cooperation with an Input Pin Interrupt to call your function.
The catch is your function is now part of an ISR (Interrupt Service Routine), and must be lean / mean, and follow certain rules. More to read on:
https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/
What if your to-be-called function is a little bit fat and lazy, with some delay(), waiting loops, etc. making it’s incompatible with hardware interrupt ?
The second best choice is solutions which :
- Use non-blocking functions in
loop() - Permit
non-blocking AutoReConnectfeature to
- auto(re)connect to the
best WiFi AP availablein the AP list (according to quality: highest RSSI/reliability APs first) - auto(re)connect to the
best Blynk server availablein the Blynk-Server list (according to priority: local Blynk servers first, then Cloud-based servers next)
Design principles of AutoReConnect
The design principles are as follows:
- Normal functions in the
loop(), as well as those called bytimerswhich are consideredmission-semi-critical, and must not be interfered or blocked by any other bad tasks,intentionally or unintentionally. This principle can be applied to any of your projects. - WiFi is considered just a communications function. Being connected or not must not interfere with the
mission-semi-criticaltasks. - Enable multiple WiFi APs in a list, so that the program can search and use the best and still available AP in case the currently used AP is out-of-service.
- Blynk is considered just a
Graphical-User-Interface (GUI). Being connected or not must not interfere with themission-semi-criticaltasks. - Enable multiple Blynk Servers (local and cloud-based servers unlimited) in a list, so that the program can search and use the best and still available Blynk Server in case the currently used server is out-of-service.
Certainly, with Blynk GUI, we can achieve many more great features, such as remote check and control, configurable test case and value , etc. when possible and available.
This can be applied in many projects requiring reliable system control, where good, bad, or no connection has no effect on the operation of the system.
Examples
#ifndef ESP32
#error This code is intended to run on the ESP32 platform! Please check your Tools->Board setting.
#endif
#include <WiFi.h>
#include <WiFiMulti.h>
#include <BlynkSimpleEsp32.h>
#define BLYNK_CONNECT_TIMEOUT_MS 5000L
#define BLYNK_SERVER_MAX_LEN 32
#define BLYNK_TOKEN_MAX_LEN 32
typedef struct
char blynk_server[BLYNK_SERVER_MAX_LEN + 1];
char blynk_token [BLYNK_TOKEN_MAX_LEN + 1];
} Blynk_Credentials;
Blynk_Credentials Blynk_Creds[] =
{ "acct1.duckdns.org", "blynk-token1"},
{ "acct2.duckdns.org", "blynk-token2"},
{ "192.168.2.110", "blynk-token3"},
{ "192.168.2.112", "blynk-token4"},
{ "blynk-cloud.com", "blynk-token5"},
{ "blynk-cloud.com", "blynk-token6"}
#define NUMBER_BLYNK_SERVERS ( sizeof(Blynk_Creds) / sizeof(Blynk_Credentials) )
#define BLYNK_SERVER_HARDWARE_PORT 8080
#define SSID_MAX_LEN 32
#define PASS_MAX_LEN 64
typedef struct
char ssid[SSID_MAX_LEN + 1];
char pass[PASS_MAX_LEN + 1];
} WiFi_Credentials;
WiFi_Credentials WiFi_Creds[] =
{ "ssid1", "pass1"},
{ "ssid2", "pass2"},
{ "ssid3", "pass3"},
{ "ssid4", "pass4"},
#define NUMBER_SSIDS ( sizeof(WiFi_Creds) / sizeof(WiFi_Credentials) )
WiFiMulti wifiMulti;
// For ESP32, this better be 2000 to enable connect the 1st time
#define WIFI_MULTI_CONNECT_WAITING_MS 2000L
uint8_t status;
uint8_t connectMultiWiFi(void)
Serial.println("\nConnecting Wifi...");
int i = 0;
status = wifiMulti.run();
delay(WIFI_MULTI_CONNECT_WAITING_MS);
while ( ( i++ < 10 ) && ( status != WL_CONNECTED ) )
if ( status == WL_CONNECTED )
break;
Serial.println("WiFi connected to after " + String(i) + " times.");
Serial.println("SSID = " + WiFi.SSID());
Serial.println("RSSI = " + String(WiFi.RSSI()));
Serial.println("Channel: " + String(WiFi.channel()));
Serial.print("IP address: ");
Serial.println("WiFi not connected");
return status;
bool connectMultiBlynk(void)
for (int i = 0; i < NUMBER_BLYNK_SERVERS; i++)
Blynk.config(Blynk_Creds[i].blynk_token, Blynk_Creds[i].blynk_server, BLYNK_SERVER_HARDWARE_PORT);
if ( Blynk.connect(BLYNK_CONNECT_TIMEOUT_MS) )
Serial.println("Blynk connected to #" + String(i));
Serial.println("Blynk Server = " + String(Blynk_Creds[i].blynk_server));
Serial.println("Blynk Token = " + String(Blynk_Creds[i].blynk_token));
return true;
Serial.println("Blynk not connected");
return false;
void heartBeatPrint(void)
static int num = 1;
if (Blynk.connected())
Serial.print("B");
Serial.print("F");
if (num == 80)
Serial.println();
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
void check_status()
static unsigned long checkstatus_timeout = 0;
#define STATUS_CHECK_INTERVAL 15000L
// Send status report every STATUS_REPORT_INTERVAL (60) seconds: we don't need to send updates frequently if there is no status change.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
// report status to Blynk
heartBeatPrint();
checkstatus_timeout = millis() + STATUS_CHECK_INTERVAL;
Serial.println("\nStart MultiBlynkWiFi_ESP32");
for (int i = 0; i < NUMBER_SSIDS; i++)
wifiMulti.addAP(WiFi_Creds[i].ssid, WiFi_Creds[i].pass);
if ( connectMultiWiFi() )
connectMultiBlynk();
if ( ( status = WiFi.status() ) != WL_CONNECTED )
else if ( !Blynk.connected() )
if ( Blynk.connected() )
check_status();
Contributions and thanks
- Thanks to Madhukesh for repetitively giving a lots of unusual requests and giving reasons to start this library.
