#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME "Hot Water Tank Status"
#define BLYNK_AUTH_TOKEN ""
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "DHT.h"
#define DHTTYPE DHT22
#define DHTPIN 2 //pin gpio 12 in sensor
DHT dht(DHTPIN, DHTTYPE);
//connect DHT22 leg 1 to 5v on wemos, leg 2 to d4 ( # 2 in code) on wemos, leg 4 to ground on wemos)
// blynk two guages, v0 pin and v1 pin
char ssid[] = "";
char pass[] = "";
float t;
float h;
bool temperatureMoved = true;
int maxvalue ;
dht.begin();
timer.setInterval(2000, sendUptime);
// for Arudino OTA code start below
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
ArduinoOTA.setHostname("hot water tank flue gas temp");
// No authentication by default
// ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_FS
type = "filesystem";
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) {
Serial.println("Auth Failed");
} else if (error == OTA_BEGIN_ERROR) {
Serial.println("Begin Failed");
} else if (error == OTA_CONNECT_ERROR) {
Serial.println("Connect Failed");
} else if (error == OTA_RECEIVE_ERROR) {
Serial.println("Receive Failed");
} else if (error == OTA_END_ERROR) {
Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
// Arduino OTA code end
BLYNK_WRITE(V2)
maxvalue = param.asInt();
void sendUptime()
float h = dht.readHumidity();
Blynk.virtualWrite(V0, t); // virtual pin
Blynk.virtualWrite(V1, h); // virtual pin
if ((t < maxvalue) && (temperatureMoved == true)) {
temperatureMoved = false;
// Blynk.notify(String("STAND BY mode. Flue Temp:") + t + String("C"));
Blynk.logEvent("TankStandyBy");
if ((t >= maxvalue) && (temperatureMoved == false)) {
// Blynk.notify(String("Water heater ON. Flue Temp:") + t + String("C"));
Blynk.logEvent("HotWaterTankONLINE");
ArduinoOTA.handle(); // Arduino OTA
Hello guys,
this worked with Legacy Blynk but after migrating to Blynk IOT, it only works partially. I am able to tell temp/humidity along with mapping temp chart via superchart. however there is slider widget which lets me set a setpoint, if the temp goes about that set point, the program should notify me or if the temp goes below, however that portion is not working which is where i need your help.
