code for ESP8266WiFI
/ Comment this out to disable prints and save space */ #define BLYNK_PRINT Serial
#include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h>
int ir_pin = 13;
int counter = 0;
int hitObject = false;
char auth[] = “YourAuthToken”;
// Set password to “” for open networks.
char ssid[] = “YourNetworkName”;
char pass[] = “YourPassword”;
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void myTimerEvent()
// Please don’t send more that 10 values per second.
// You can also specify server: //Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 80); //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
pinMode(ir_pin,INPUT);
int val = digitalRead(ir_pin);
if( (val == 1) && (hitObject == false) ){
counter++;
hitObject = true;
Serial.print("Counter = ");
Serial.println( counter);
}else if( (val ==0) && (hitObject == true) ) {
hitObject = false;
but I not sure
BLYNK_READ(5) { // Usually, you will need to respond with a virtual pin value. Blynk.virtualWrite(5, some_value); }
how I can get the pin value number in this case 123456…
the proyect is count parts with a inductive sensor and display the numbers with blynk app
the pin reads state, the sensor this high and add a number in sequence 1.2.3.4.5
As mentioned, please edit your post so that your code is formatted correctly. It is very hard to read as is.
How fast do the parts appear? Sounds like a good use for an interrupt routine.
Here is an example semi based off the Push Notification Button example on the Sketch Builder. It is Untested so no guarantees it will work, as I don’t use interrupts all to often. Also be aware of switch bounce, depending on how the sensor works this may or may not be a problem.
Display Widget on Virtual Pin 5
http://twitter.com/blynk_app
char pass[] = "YourPassword";
int ir_pin = 13;
int resetPin = 12;
int counter = 0;
void notifyOnButtonPress()
counter++;
Blynk.virtualWrite(V5, counter);
void resetCount()
if (digitalRead(resetPin) == LOW)
counter = 0;
pinMode(resetPin, INPUT_PULLUP);
// Setup notification button on pin 2
pinMode(ir_pin, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(ir_pin), notifyOnButtonPress, RISING);
timer.setInterval(1000L, resetCount);
