I have a local server running on Raspbery Pi with two active projects both using Arduino Uno hardware. I run the latest update of Blynk App on IOS. I would like to experiment using some IFTTT recipes to set virtual pin states on My Blynk connected hardware.
I realise that I will first need to update my local server to the latest version but after that I am unsure as to how I am going to get it to work. I have set up an IFTTT account, loaded the ‘IF’ IOS app on my phone and connected to the ‘Maker’ channel which gave me a KEY.
What do I need to do next?
What do I do with the KEY given to me from the ‘Maker’ channel?
For a bit more clarity, the first recipe I would like to run is to get the IFTTT app, to set a Virtual Pin High on the Blynk hardware when I am coming home from work.
@Dmitriy Can you explain the URL? I thought that trigger (GPS) would result in an action call to the Blynk server. Is this only useful for those running a private server?
@Dmitriy i’am able to read any D pin or V pin , but using PUT to change a value of pin never worked with me.
i tried to implement it in Node-RED with no hope.
i start debugging it using Postman chrome extension and others that used to work with many restful APIs
but not working at all.
Dmitriy, thanks for the tip on the other post. I’ve done everything on ifttt and tried to activate V1 when i receive an email from myself but I am getting and error:
Maker Action Error
An error with Maker prevented your Recipe from working. Edit the Maker Channel or try again. If errors persist, visit the Help page for support.
