IFTTT and Blynk - questions
curl --include --request PUT --header "Content-Type: application/json" --data-binary "[\"1\"]" 'http://cloud.blynk.cc:8080/token/pin/d8'
CURL works fine. I believe something is wrong with IFTTT escaping… Cause it was working fine.
Works with the request “["1"]” but not with [“1”]. Automate running :smiley:
Hi @Dmytro
I have finally got back around to trying IFTTT and am not having any luck.
The IF is time based and the THEN is the maker channel.
URL - http://notmyreal.ddns.net:8080/blynkauthtoken/pin/V30
method - put
content type - application/json
body - “[“1”]”
I get the error… (on IFTTT)
Unable to make web request: Error: ETIMEDOUT
My Local server runs on a raspberry pi behind a router. I have setup port forwarding on the router to send any traffic on port 8080 to the Blynk local server IP (192.168.0.201)
Do you have any ideas why IFTTT is not working for me? I have tried sending different strings in the ‘body’ but have had no success at all.
@NickMurray Hi. This is Blynk bug I fixed it already. I’ll do new release 0.13.2 with fixes today-tomorrow.
A new release of what?
Local sever?
iOS app?
Blynk library?
Just not sure what I will need to update. I am iOS user.
This is server issue
Ok, thanks. I’ll update my server
Is Blynk working with IFTTT maker channel. ?
For me it still seems to be not working. I am using a simple DO button and put a value “1” to virtual pin V1. does not seem to be working ?
@RaPo what is your account? What IP ping shows for you?
My account is raghu.ponuganti@gmail.com.
IP ping do you mean ping www.blynk-cloud.com from laptop…?
Unfortunately it shows “Ping request could not find the host www.blynk-cloud.com.”
I IFTTT URL I used http://blynk-cloud:8080/My authcode/pin/V1
Please try to ping blynk-cloud.com not www.blynk-cloud.com.
For IFTTT API try to use those API and tell me if that works for you.
Here is the ping ip address : 46.101.143.225
For IFTTT I am already using only blynk-cloud.com …It still does not work.
@RaPo I have the same IP and it works fine. Are you including the port, 8080?
Hi, yes In IFTTT I am including the port number, 8080
For DO I have:
http://46.101.143.225:8080/token/pin/V6
PUT method
application/json for Content Type
[“1”] for body to turn on the virtual pin.
Similar for you @RaPo ?
@Costas this was in my configuration. But after replacing blynk-cloud.com with the ip address it works with IFTTT. Thank you.
@RaPo please try IP (46.101.143.225) instead of blynk-cloud.com does that resolve issue? Also 8080 not needed anymore.
for me somehow IFTTT works only if I use [<<<1>>>] in the body.
@Dmytro yes it works when I use IP address. Thank you.
@Pavlo it worked for me with [“1”] in body. I could turn on a light with it.
1 quesstion, how can I send mutiple values. For example for zeRGBa to send RGB values.
I use merge mode so is it [“255” “255” “255”] …?
Thanks.
[“255” “255” “255”]
Should be
["255","255","255"]
