@Mahedy_Hasan As stated, you are not likely to find perfectly custom fitting code, nor someone to help you learn coding at the probable level you may need… but here is one of my rover projects that should have very similar driver control characteristics ( 2x BTS7960 vs L293D )… but you MUST know enough to modify the code, so remember, Google is your friend
