Hello everybody! I use esp8266 12, I have tried a piece of IR record and send, I want to create a button to press eeprom function for 3 times eeprom, and 3 buttons to send IR, I’m having difficulty in reading and writing structure, If anyone knows how to ask for help, I thank you very much
#include <IRremoteESP8266…h>
#include <IRrecv .h>
#include <IRsend.h>
const uint8_t PIN_IR_RX = 13; // D7
const uint8_t PIN_IR_TX = 15; // D8
const uint16_t CAPTURE_BUFFER_SIZE = 256;
const uint8_t TIMEOUT = 45; // 15
const uint32_t BLINK_TIMEOUT = 5000; // 5 sec.
IRrecv irRX(PIN_IR_RX, CAPTURE_BUFFER_SIZE, TIMEOUT, true);
IRsend irTX(PIN_IR_TX);
decode_results results;
uint16_t rawBuf[CAPTURE_BUFFER_SIZE];
uint16_t rawBufLen = 0;
uint32_t nextBlink;
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
Serial.println();
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
irRX.enableIRIn();
irTX.begin();
bool cloneBuffer(decode_results *results) {
static const char irTypes[][14] PROGMEM = { “UNKNOWN”, “UNUSED”, “RC5”, “RC6”, “NEC”, “SONY”, “PANASONIC”, “JVC”, “SAMSUNG”, “WHYNTER”,
“AIWA_RC_T501”, “LG”, “SANYO”, “MITSUBISHI”, “DISH”, “SHARP”, “COOLIX”, “DAIKIN”, “DENON”, “KELVINATOR”, “SHERWOOD”, “MITSUBISHI_AC”,
“RCMM”, “SANYO_LC7461”, “RC5X”, “GREE”, “PRONTO”, “NEC_LIKE”, “ARGO”, “TROTEC” };
if (results->repeat) {
Serial.println(F(“IR sequence is repeat code, ignored!”));
return false;
if (results->overflow) {
Serial.println(F(“IR sequence too big!”));
return false;
Serial.print(F(“IR type: “));
Serial.print(FPSTR(irTypes[results->decode_type - UNKNOWN]));
Serial.print(F(”, code: 0x”));
Serial.print((uint32_t)results->value, HEX);
Serial.print(F(" ("));
Serial.print(results->bits);
Serial.println(F(" bits)"));
rawBufLen = 0;
for (uint16_t i = 1; i < results->rawlen; ++i) {
uint32_t usecs;
for (usecs = results->rawbuf[i] * RAWTICK; usecs > UINT16_MAX; usecs -= UINT16_MAX) {
rawBuf[rawBufLen++] = UINT16_MAX;
rawBuf[rawBufLen++] = 0;
rawBuf[rawBufLen++] = usecs;
Serial.print(F("Raw code buffer length: "));
Serial.println(rawBufLen);
nextBlink = millis() + BLINK_TIMEOUT;
return true;
void ledPulse(uint32_t onDuration = 500, uint32_t offDuration = 0, uint8_t count = 1) {
while (count–) {
digitalWrite(LED_BUILTIN, LOW);
delay(onDuration);
delay(offDuration);
if (irRX.decode(&results)) {
if (cloneBuffer(&results)) {
ledPulse(250, 100, 3);
irRX.resume();
if (rawBufLen && ((int32_t)millis() >= (int32_t)nextBlink)) {
irRX.disableIRIn();
irTX.sendRaw(rawBuf, rawBufLen, 38);
irRX.enableIRIn();
ledPulse(250);
yield();
