BLYNK
I need to set timers for relay with esp-01
I need to set timers for relay with esp-01.I have the code in my hand,but it has some sort of problems.
When i set the timer for hours,it will stop in few seconds.
#define relay
char auth[] = "0fc5f00064694bf1a3489d3170c66868";
char ssid[] = "Redmi";
char pass[] = "";
BLYNK_WRITE(V1) {
  long startTimeInSecs = param[0].asLong();
  Serial.println(startTimeInSecs);
  Serial.println();
  if(digitalRead(1) == LOW)
    delay(startTimeInSecs);
    digitalWrite(1,HIGH);
    digitalWrite(1,LOW);
BLYNK_WRITE(V2) //Button Widget is writing to pin V1
  int pinData = param.asInt();
  if(pinData == 1)
  pinMode(1, OUTPUT);
Any one help me???
Please don’t dump your unformatted code and help issue in someone else’s topic. I have moved your question into its own topic and formatted your code as required.
Blynk - FTFC
Read through this whole topic and experiment until you understand it better… the code section you have is for the seconds part, not the hours.
