Hello, i’m doing a college job and I need show a value of current sensor in my smart phone. For this i’m using Blynk to make app. My problem is that I can not show the data read by the sensor in Blynk, can anyone help me?
I’m using Arduino MEGA 2560 - Bluetooth Communication.
My code:
#include "EmonLib.h" //sensor de corrente
#include <Ultrasonic.h> // sensor ultrassonico
#include <EEPROM.h>
char buf; // ultrassonico
unsigned short flag = 0; //flag para armazenar valor anterior do sensor ultrasonico
#define pino_trigger 4 // ultrassonico
#define pino_echo 5 // ultrassonico
Ultrasonic ultrasonic(pino_trigger, pino_echo);
EnergyMonitor emon1; // corrente
//Tensao da rede eletrica
int rede = 127.0;
//Pino do sensor SCT
int pino_sct = A0;
//variaveis para contar tempo
double timems=0, time_ant=0, time_atual=0, tempo = 0;
//variaveis para calculo de kwh
double kwtotal=0;
double Irms = 0;
char auth[] = "cbd0eb8743e74c6c993552b0b9df1ef3";
SoftwareSerial SerialBLE(10, 11); // RX, TX
void corrente()
Blynk.virtualWrite(V0, Irms);
void potenciaInsta()
Blynk.virtualWrite(V1, Irms*rede/1000);
void potenciaTotal()
Blynk.virtualWrite(V2, kwtotal);
void gastoRede()
Blynk.virtualWrite(V3,kwtotal*0.78063);
//Define o pino 7 como saida
pinMode(7, OUTPUT);//saida do relé
pinMode(13, OUTPUT);
SerialBLE.begin(9600);
Blynk.begin(SerialBLE,auth);
Serial.println("Lendo dados do sensor");
//Pino, calibracao - Cur Const= Ratio/BurdenR. 1800/62 = 29.
emon1.current(pino_sct, 16); // calibração corrente com o multimetro
timer.setInterval(1000L, corrente);
timer.setInterval(1000L, potenciaInsta);
timer.setInterval(1000L, potenciaTotal);
timer.setInterval(1000L, gastoRede);
long microsec = ultrasonic.timing();
float cmMsec, inMsec;
time_atual = millis() - time_ant;
time_ant = time_ant + time_atual;
Irms = emon1.calcIrms(1480); //calcula Irms
kwtotal = kwtotal + (double)Irms*rede*(time_atual/3600E6); //total de kw consumido
//sensor ultrasonico
cmMsec = ultrasonic.convert(microsec, Ultrasonic::CM);
//inMsec = ultrasonic.convert(microsec, Ultrasonic::IN);
//Serial.print("Distancia em cm: ");
//Serial.print(cmMsec);
//Serial.print(" - Distancia em polegadas: ");
//Serial.println(inMsec);
//Mostra o valor da corrente
Serial.print("Corrente: ");
Serial.print(Irms);
//Calcula e mostra o valor da potencia
Serial.print(" Potencia: ");
Serial.println(Irms*rede);
//mostra o valor de kw instantaneo
Serial.print(" Kw instantaneo: ");
Serial.println(Irms*rede/1000,10); // 3600E3
//mostra o total de kwh consumido
Serial.print(" Kwh total consumido: ");
Serial.println(kwtotal,10);
//mostra o valor em reais
Serial.print("Valor da conta atual: R$");
Serial.println(kwtotal*0.78063191,10); // valor do Kwh da conta de energia
//mostra o valor de kwh total estipulado para um mês
Serial.print(" Kwh total estipulado para 30 dias: ");
Serial.println((Irms*rede*720)/1000); //valor de kwh atual vezes 720horas de 30dias
Serial.println(time_atual);
if(cmMsec <20) //seta flag dizendo que foi menor que 20cm
flag = 1;
if(cmMsec >30 && flag==1) //se for maior que 30 e sensor foi acionado anteriormente
digitalWrite(13, !digitalRead(13)); //inverte estado do led
flag = 0; //limpa flag
delay(10000);
