I have been working on an app that uses tabs and many other widgets.
Suddenly if I access one of the tabs, it crashes the Android app. (It is the second tab called ‘Cab’
Restarting the app does not help, it dies attempting to open any other Blynk apps too.
The only way to clear the problem is to uninstall and reinstall the app.
Once newly installed, I was able to clone the old app from its QR code, but as soon as I access the tab again, it corrupts the app again.
I may have sent a bad widget property into one of the widgets on the tab, but I cannot tell.
I have captured the json app definition and its QR code.
The json did contain a confidential URL that I have replaced with a space.
I am happy to provide QR code to Blynk devs so that someone can reproduce and debug what is causing the crash and corruption. I can’t edit out the URL from the QR code though so it can’t get posted publicly.
I am hoping that a Blynk dev can determine what is causing the corruption of the Blynk app. (I am sure you want to know about such a nasty one!)
Once that is known, perhaps I can send an approriate propertyWrite to correct any error condition that is the cause, before a fix can be made for the app.
App was running on a Nexus 6P.
Here is the json:
(I see that all the tabs have “id”: 0 not sure if that is normal)
"id": 1960382021,
"parentId": -1,
"isPreview": false,
"name": "cab",
"createdAt": 1548346431326,
"updatedAt": 1550863669890,
"widgets": [
"type": "VERTICAL_SLIDER",
"id": 9888,
"x": 3,
"y": 5,
"color": 600084223,
"width": 1,
"height": 4,
"tabId": 1,
"isDefaultColor": true,
"deviceId": 0,
"pinType": "VIRTUAL",
"pin": 2,
"pwmMode": false,
"rangeMappingOn": false,
"min": 200,
"max": 0,
"value": "200",
"sendOnReleaseOn": true,
"frequency": 100,
"maximumFractionDigits": 0,
"showValueOn": false
"type": "STYLED_BUTTON",
"id": 146791,
"x": 6,
"y": 5,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"isDefaultColor": false,
"deviceId": 0,
"pin": 11,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": "Headlights",
"textColor": 255,
"backgroundColor": 79755519
"offButtonState": {
"textColor": 255,
"backgroundColor": 600084223
"fontSize": "SMALL",
"edge": "ROUNDED",
"buttonStyle": "SOLID",
"lockSize": false
"type": "IMAGE",
"id": 129432,
"x": 0,
"y": 2,
"color": 0,
"width": 6,
"height": 3,
"tabId": 1,
"deviceId": 0,
"pin": 0,
"pwmMode": false,
"min": 0,
"max": 0,
"source": "URL",
"scaling": "FIT",
"urls": [
"opacity": 100,
"scale": 100,
"rotation": 0
"id": 36720,
"x": 4,
"y": 6,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 12,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": "Shunt",
"textColor": 255,
"offButtonState": {
"text": "Shunt",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 185462,
"x": 4,
"y": 5,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 10,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"textColor": 255,
"offButtonState": {
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 100878,
"x": 6,
"y": 6,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 13,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": "Shunt",
"textColor": 255,
"offButtonState": {
"text": "Shunt",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 13469,
"x": 4,
"y": 7,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 14,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": "Accel.",
"textColor": 255,
"offButtonState": {
"text": "Accel.",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 141711,
"x": 5,
"y": 8,
"color": 0,
"width": 3,
"height": 1,
"tabId": 0,
"label": "Ver 2019022201",
"deviceId": 0,
"pin": 20,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "104",
"pushMode": true,
"onButtonState": {
"text": "⌛",
"textColor": -1,
"offButtonState": {
"text": "Update",
"textColor": 255,
"fontSize": "MEDIUM",
"edge": "ROUNDED",
"lockSize": false
"type": "IMAGE",
"id": 144427,
"x": 6,
"y": 2,
"color": 0,
"width": 2,
"height": 2,
"tabId": 1,
"deviceId": 0,
"pin": 4,
"pwmMode": false,
"min": 0,
"max": 0,
"source": "URL",
"scaling": "FIT",
"urls": [
"opacity": 100,
"scale": 100,
"rotation": 0
"id": 71695,
"x": 6,
"y": 7,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 15,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": " ",
"textColor": 255,
"offButtonState": {
"text": " ",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"type": "MENU",
"id": 40473,
"x": 0,
"y": 1,
"color": 600084223,
"width": 6,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 1,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "1",
"labels": [
"<none>",
"S7 (141) ",
"S3 (13) ",
"Tin plate (56) ",
"S5 (24) ",
"Blue Diesel (80) n/a",
"L:Köf II (23) ",
"Ocean Blue (20) ",
"D-Zug (3) n/a",
"Coal hauler (97) ",
"BR 81 (78) ",
"Rollendelandstrasse (5) ",
"Klasse C (10) ",
"Baden (19) ",
"Würtenburgerin (2) ",
"E18 (18) ",
"L:BR 85 006 heavy tank (6) ",
"ICE (40) ",
"S1 (111) ",
"L:S 3/6 - 18 434 (34) ",
"Linus diesel (24) n/a",
"Umbau (33) ",
"Lucy Express (60) n/a",
"Sonderzug (12) ",
"Railion (22) ",
"Cargo Sprinter (70) ",
"L:Heavy Goods class 50 (53) ",
"Rheingold (36) ",
"Transformer (16) ",
"Container (74) ",
"L:Streamlines class 3 (31) "
"fontSize": "LARGE",
"iconColor": 600084223
"id": 48558,
"x": 4,
"y": 8,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 16,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": " ",
"textColor": 255,
"offButtonState": {
"text": " ",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 23119,
"x": 6,
"y": 8,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 17,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "1",
"pushMode": false,
"onButtonState": {
"text": " ",
"textColor": 255,
"offButtonState": {
"text": " ",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"type": "DIGIT4_DISPLAY",
"id": 91736,
"x": 0,
"y": 5,
"color": 600084223,
"width": 2,
"height": 1,
"tabId": 1,
"label": "Km/H",
"deviceId": 0,
"pin": 5,
"pwmMode": false,
"min": 45,
"max": 300,
"value": "0/0",
"frequency": 0,
"fontSize": "LARGE"
"id": 39341,
"x": 0,
"y": 6,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"label": " ",
"deviceId": 0,
"pin": 3,
"pwmMode": false,
"min": 1,
"max": 0,
"value": "1",
"pushMode": false,
"onButtonState": {
"text": "⬇️",
"textColor": 255,
"offButtonState": {
"text": "⬆️",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": true
"type": "VERTICAL_LEVEL_DISPLAY",
"id": 105814,
"x": 2,
"y": 5,
"color": 600084223,
"width": 1,
"height": 4,
"tabId": 1,
"deviceId": 0,
"pin": 7,
"pwmMode": false,
"min": 0,
"max": 200,
"value": "0",
"frequency": 0,
"isAxisFlipOn": false,
"type": "TABS",
"id": 51933,
"x": 0,
"y": 0,
"color": 421142527,
"width": 8,
"height": 1,
"tabId": -1,
"tabs": [
"id": 0,
"label": "Power"
"id": 0,
"label": "Cab"
"id": 0,
"label": "k83+s88"
"id": 0,
"label": "stations"
"id": 0,
"label": "events"
"id": 0,
"label": "log"
"activeTxtColor": 79755519,
"underlineColor": 79755519,
"textColor": 600084223
"type": "SEGMENTED_CONTROL",
"id": 61801,
"x": 0,
"y": 2,
"color": -750560001,
"width": 8,
"height": 1,
"tabId": 0,
"deviceId": 0,
"pin": 21,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "1",
"labels": [
"Off",
"On",
"Halt"
"type": "STEP",
"id": 131033,
"x": 2,
"y": 1,
"color": 600084223,
"width": 4,
"height": 1,
"tabId": 2,
"label": "k83/4",
"deviceId": 0,
"pin": 23,
"pwmMode": false,
"min": 1,
"max": 1023,
"value": "27",
"step": 1,
"isArrowsOn": true,
"isLoopOn": false,
"isSendStep": false,
"frequency": 100,
"showValueOn": true
"type": "STEP",
"id": 95005,
"x": 2,
"y": 4,
"color": 600084223,
"width": 4,
"height": 1,
"tabId": 2,
"label": "s88",
"deviceId": 0,
"pin": 25,
"pwmMode": false,
"min": 1,
"max": 1023,
"value": "22",
"step": 1,
"isArrowsOn": true,
"isLoopOn": false,
"frequency": 100,
"showValueOn": true
"type": "LED",
"id": 98270,
"x": 2,
"y": 5,
"color": 600084223,
"width": 4,
"height": 4,
"tabId": 2,
"label": " ",
"deviceId": 0,
"pin": 26,
"pwmMode": false,
"min": 0,
"max": 0
"id": 197196,
"x": 0,
"y": 2,
"color": 79755519,
"width": 8,
"height": 1,
"tabId": 2,
"deviceId": 0,
"pin": 24,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "2",
"labels": [
"red",
"green"
"type": "MENU",
"id": 192247,
"x": 0,
"y": 1,
"color": 600084223,
"width": 8,
"height": 1,
"tabId": 3,
"label": "Station",
"deviceId": 0,
"pin": 30,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "1",
"labels": [
"Wilsnack Hbf.",
"Senklerdorf"
"type": "MENU",
"id": 100111,
"x": 1,
"y": 3,
"color": 600084223,
"width": 7,
"height": 1,
"tabId": 3,
"label": "Track",
"deviceId": 0,
"pin": 31,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "3",
"labels": [
"1",
"2",
"3"
"id": 147108,
"x": 4,
"y": 7,
"color": 0,
"width": 4,
"height": 1,
"tabId": 3,
"deviceId": 0,
"pin": 33,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": true,
"onButtonState": {
"text": "dispatch",
"textColor": -1,
"offButtonState": {
"text": "dispatch",
"textColor": 255,
"edge": "PILL",
"lockSize": false
"type": "MENU",
"id": 27413,
"x": 2,
"y": 5,
"color": 600084223,
"width": 6,
"height": 1,
"tabId": 3,
"label": "Destination",
"deviceId": 0,
"pin": 32,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "1",
"labels": [
"Senklerdorf",
"Schattenbahnhof"
"type": "TERMINAL",
"id": 179289,
"x": 0,
"y": 1,
"color": 255,
"width": 8,
"height": 7,
"tabId": 5,
"deviceId": 0,
"pin": 22,
"pwmMode": false,
"min": 0,
"max": 0,
"autoScrollOn": true,
"terminalInputOn": false,
"textLightOn": true,
"attachNewLine": false
"type": "MENU",
"id": 145011,
"x": 0,
"y": 1,
"color": 600084223,
"width": 8,
"height": 1,
"tabId": 4,
"label": "Event",
"deviceId": 0,
"pin": 27,
"pwmMode": false,
"min": 0,
"max": 0,
"value": "47",
"labels": [
"Dispatch Hidden 1",
"Dispatch Hidden 6",
"Dispatch Hidden 2",
"Dispatch Hidden 3",
"Dispatch Hidden 4",
"Dispatch Farm 1",
"Welder",
"Locomotive sheds",
"Locomotive sheds off",
"Bw yard lights",
"Night",
"Day 10s",
"Crickets",
"Bells",
"Crows",
"Crow",
"Band",
"Sheep",
"Dispatch Farm 3",
"Dispatch Farm 2",
"Dispatch Goods East",
"Sparrows",
"BR 41",
"Dispatch S-Bahn 1",
"Dispatch Hidden 8",
"Dispatch Hidden 7",
"Boyd report",
"Dispatch Hidden 5",
"Crow call",
"Dispatch Hbf 4",
"Ignore HTTP",
"Dispatch Hbf 2",
"Dispatch Goods West",
"Dispatch Hbf 3",
"Dispatch Hbf 5",
"Dispatch S-Bahn 2",
"Power OFF",
"Welcome",
"Chickens",
"Barnyard",
"Senklerdorf Bells (long)",
"Senklerdorf sparrows",
"Senklerdorf thunder",
"Thunderstorm",
"Wilsnack thunder",
"Senklerdorf bird",
"Wilsnack crow1",
"Wilsnack Bells",
"Streetlights OFF",
"Apartment lights",
"Apartments dark",
"Street lights",
"Crane wagon sounds",
"Crane wagon next sound",
"Bridge lights",
"Sunset",
"Sunrise",
"Aurora",
"Rooster",
"Rooster",
"chimney red",
"Chimney OFF",
"Chimney",
"Auto smoke",
"Intellibox",
"Announcements",
"Allow route chaining",
"Allow sounds"
"id": 189119,
"x": 5,
"y": 3,
"color": 0,
"width": 2,
"height": 1,
"tabId": 4,
"deviceId": 0,
"pin": 28,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": true,
"onButtonState": {
"text": "⌛",
"textColor": -1,
"offButtonState": {
"text": "▶️",
"textColor": 255,
"edge": "PILL",
"lockSize": false
"id": 113183,
"x": 0,
"y": 8,
"color": 0,
"width": 4,
"height": 1,
"tabId": 0,
"label": "192.168.86.156",
"deviceId": 0,
"pin": 29,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": true,
"onButtonState": {
"text": "⏳",
"textColor": -1,
"offButtonState": {
"text": "📶 -43dBm",
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 24621,
"x": 6,
"y": 4,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 6,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0.0",
"pushMode": true,
"onButtonState": {
"text": "8",
"textColor": 255,
"backgroundColor": -1
"offButtonState": {
"text": "8",
"textColor": 255,
"edge": "SHARP",
"lockSize": false
"id": 82758,
"x": 1,
"y": 4,
"color": 0,
"width": 6,
"height": 1,
"tabId": 0,
"deviceId": 0,
"pin": 34,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": false,
"onButtonState": {
"text": "Ignore unexpected trains",
"textColor": 255,
"offButtonState": {
"textColor": 255,
"edge": "ROUNDED",
"lockSize": false
"id": 156950,
"x": 0,
"y": 8,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 35,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "1",
"pushMode": false,
"onButtonState": {
"text": "Manual",
"textColor": 255,
"offButtonState": {
"text": "Manual",
"textColor": 255,
"edge": "PILL",
"lockSize": false
"id": 31996,
"x": 0,
"y": 6,
"color": 600084223,
"width": 8,
"height": 1,
"tabId": 0,
"label": "Connection",
"deviceId": 0,
"pin": 36,
"pwmMode": false,
"min": 0,
"max": 1023,
"value": " ",
"frequency": 0,
"fontSize": "LARGE"
"id": 149478,
"x": 0,
"y": 7,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 37,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": true,
"onButtonState": {
"text": "🛑",
"textColor": -1,
"backgroundColor": -750560001
"offButtonState": {
"text": "🛑",
"textColor": 255,
"edge": "PILL",
"lockSize": false
"id": 21910,
"x": 6,
"y": 1,
"color": 0,
"width": 2,
"height": 1,
"tabId": 1,
"deviceId": 0,
"pin": 38,
"pwmMode": false,
"min": 0,
"max": 1,
"value": "0",
"pushMode": true,
"onButtonState": {
"text": "⏳",
"textColor": -1,
"offButtonState": {
"text": "↩️",
"textColor": 255,
"edge": "PILL",
"lockSize": false
"devices": [
"id": 0,
"name": "cab",
"boardType": "ESP8266",
"vendor": "New Device",
"connectionType": "WI_FI",
"isUserIcon": false
"theme": "Blynk",
"keepScreenOn": false,
"isAppConnectedOn": false,
"isNotificationsOff": false,
"isShared": false,
"isActive": true,
"widgetBackgroundOn": false,
"color": 0,
