I can't find the bug
I have a couple of issues with this project. Line 89 Blynk.virtualWrite(0, counter);
V0 is a numerical input box. I cannot get this box to update. The notification I recieve on line 90 gives me the correct reading for ‘counter’ but it is not put into V0 correctly.
I also get disconnects from blynk after the 1 second timer has run. It seems random, not all the time but happens when pulsing = 0 (line 166) Blynk reconnects instantly
Any help would be appeciated
#include <WidgetRTC.h> //blynk time server
char auth [] = "xxx";
WidgetRTC rtc;
// the timer object
SimpleTimer timerminute;
SimpleTimer timerhour;
volatile byte pulsing;
int pulsecount;
int noflow;
int blynkflowingvalue;
int blynknoflowvalue;
int state; //on/off state
const int pinReedSwitch = 2;
int counter;
int countminutes;
int counthours;
int lastValue;
int hournotify;
int minutenotify;
int secondnotify;
  Blynk.begin(auth);
  rtc.begin(); //begin getting time-date
  timerminute.setInterval(60000, CheckWater); // Miliseconds to seconds, every minute run function which counts time
  timerhour.setInterval(3600000, UpdateHourly); // Miliseconds to seconds, every hour run function which counts time
  pulsing = 0;
  counter = 0;
  countminutes = 0;
  counthours = 0;
  pulsecount = 0;
  noflow = 0;
  pinMode(pinReedSwitch, INPUT_PULLUP);
  Blynk.syncVirtual(2); //This gets the virtual pin value from server. (Needed for example after power loss)
  Blynk.syncVirtual(3);
  Blynk.syncVirtual(4);
  Blynk.syncVirtual(5);
  Blynk.syncVirtual(7);
  Blynk.syncVirtual(10);
    timerminute.run();
    timerhour.run();
  int value = !digitalRead(pinReedSwitch);
  if (value != lastValue)
    lastValue = value;
    if (value)
    pulsing = 1; //water is flowing set pulsing to 1
    counter++;
    countminutes++;
    counthours++;
    Serial.println("value: " + String(value));
    Serial.println("lastvalue: " + String(lastValue));
    Serial.println("Counter: " + String(counter));
  if (hour() == hournotify && minute() == minutenotify && second() == secondnotify )
    Blynk.virtualWrite(0, counter); //update how many counts/litres in last 24 hours and set it back to zero
    Blynk.notify("Water mains Feed: " +String(counter) + " litres used in last 24 hours");
    counter = 0;
    BLYNK_WRITE(2)
    blynkflowingvalue = param.asInt(); // Get value as integer
    BLYNK_WRITE(3)
    blynknoflowvalue = param.asInt(); // Get value as integer
    BLYNK_WRITE(6) //Reset Button
    noflow = 0;
    pulsecount = 0;
    pulsing = 0;
    Blynk.virtualWrite(4, LOW); //Turn off no flow error button
    Blynk.virtualWrite(5, LOW); //Turn off to much flow error
    BLYNK_WRITE(7) //on/off button
      if ( param.asInt() == 1 ) //Button high/pressed
      state = 1;
      state = 0;
BLYNK_WRITE(V10) //Time for notify
  TimeInputParam t(param);
  // Process start time
    hournotify = t.getStartHour();
    minutenotify = t.getStartMinute();
    secondnotify = t.getStartSecond();
void CheckWater()
if (state == 1)
  if (pulsing == 1)
    pulsecount++;
    Blynk.virtualWrite(1, HIGH); //Turn on flowing LED
    if (pulsecount == blynkflowingvalue)
      Blynk.virtualWrite(5, HIGH); //Turn on to much flow error button
      Blynk.notify("Warning direct mains in has been flowing for " + String(blynkflowingvalue) + " minutes. Remember to Reset");
    pulsing = 0; //We only want to see if the flow sensor pulsed at all in the one minute interval. It did, so set it back to 0
    noflow = 0; //obviously there has been flow so reset to zero
    Blynk.virtualWrite(8, countminutes); //update how many counts/litres in a minute and set it back to zero
    countminutes = 0;
  noflow++;
  Blynk.virtualWrite(1, LOW); //Turn off flowing LED
      if (noflow == blynknoflowvalue)
      Serial.println("Warning, no flow");
      Blynk.virtualWrite(4, HIGH); //Turn on no flow error button
      Blynk.notify("Warning direct mains in has not been flowing for " +String(blynknoflowvalue) + " minutes. Remember to Reset");
   pulsecount = 0; //in the one minute interval water stopped pulsing through sensor so put the pulse count to 0
   countminutes = 0;
void UpdateHourly()
Blynk.virtualWrite(9, counthours); //update how many counts/litres in an hour and set it back to zero
counthours = 0;
I’d start by reading this:
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
and make better use of your timers.
Also, you don’t need to do this:
and this:
A single BlynkTimer object can support up to 16 timer instances.
See the “Creating Interval Timers” section of this post:
Also, it’s usual (although not strictly necessary) to use the “V” prefix when referencing virtual pins in BLYNK_WRITE, Blynk.virtualWrite and Blynk.syncVirtual commands so that they’d look like this:
Blynk.virtualWrite(V0, counter);
This would make your code more readable from most Blynkers point of view.
Also, this in your void setup won’t work:
Instead, these Blynk.syncVirtual commands should be in a BLYNK_CONNECTED() callback function
See the “Synchronising the output state with the app at startup” section of this post for more info:
Thanks for all the info Pete.
I’ve made some changes to the timers. My sync’s do work not being inside the BLYNK_CONNECTED() However I can add it inside that.
Updated code below. Can you see anywhere else I am spamming the Blynk server causing errors?
I’ve removed a piece out of the loop, but not sure how I would remove the piece which is checking for the reed sensor
char auth [] = "";
WidgetRTC rtc;
// the timer object
int pulsecount;
int noflow;
int counter;
int countminutes;
int counthours;
int lastValue;
int hournotify;
int minutenotify;
int secondnotify;
  Blynk.begin(auth);
  timer.setInterval(60000, CheckWater); // Miliseconds to seconds, every minute run function which counts time
  timer.setInterval(3600000, UpdateHourly); // Miliseconds to seconds, every hour run function which counts time
  timer.setInterval(1000, DailyNotify); // Miliseconds to seconds, every hour run function which counts time
  pulsing = 0;
  counter = 0;
  countminutes = 0;
  counthours = 0;
  pulsecount = 0;
  noflow = 0;
  Blynk.syncVirtual(V2); //This gets the virtual pin value from server. (Needed for example after power loss)
  Blynk.syncVirtual(V3);
  Blynk.syncVirtual(V4);
  Blynk.syncVirtual(V5);
  Blynk.syncVirtual(V7);
  Blynk.syncVirtual(V10);
    lastValue = value;
    if (value)
    counter++;
    countminutes++;
    counthours++;
    BLYNK_WRITE(V2)
    BLYNK_WRITE(V3)
    BLYNK_WRITE(V6) //Reset Button
    noflow = 0;
    pulsecount = 0;
    pulsing = 0;
    Blynk.virtualWrite(V4, LOW); //Turn off no flow error button
    Blynk.virtualWrite(V5, LOW); //Turn off to much flow error
    BLYNK_WRITE(V7) //on/off button
      state = 1;
      state = 0;
void CheckWater()
if (state == 1)
  if (pulsing == 1)
    pulsecount++;
    Blynk.virtualWrite(V1, HIGH); //Turn on flowing LED
      Blynk.virtualWrite(V5, HIGH); //Turn on to much flow error button
    Blynk.virtualWrite(V8, countminutes); //update how many counts/litres in a minute and set it back to zero
    countminutes = 0;
  noflow++;
  Blynk.virtualWrite(V1, LOW); //Turn off flowing LED
      Blynk.virtualWrite(V4, HIGH); //Turn on no flow error button
   countminutes = 0;
void UpdateHourly()
Blynk.virtualWrite(V9, counthours); //update how many counts/litres in an hour and set it back to zero
counthours = 0;
void DailyNotify()
    Blynk.virtualWrite(V0, counter); //update how many counts/litres in last 24 hours and set it back to zero
    counter = 0;
By using a timer that checks say every 200ms, or attaching an interrupt to the pin.
