I can not access the admin page
I need help, I can not access the admin page safely.
Server -> W7
IP = Public -> “NOIP” domain = mc-casainteligente.ddns.net
TCP ports = 8443, 8442, 8441, 8080, 9443
logs.
listen.address=
server.ssl.cert=./server.crt
server.ssl.key=./server.pem
server.ssl.key.pass=xxxxx
client.ssl.cert=
client.ssl.key=
data.folder=
logs.folder=./logs
enable.native.epoll.transport=false
enable.native.openssl=false
enable.db=false
enable.raw.db.data.store=false
#ADMINISTRATION SECTION
admin.rootPath=/admin
#server.host=mc-casainteligente.ddns.net
#email used for certificate registration, could be omitted in case you already specified it in mail.properties
#contact.email=mauroviana.s@hotmail.com
allowed.administrator.ips=192.168.xxx.xxx,192.168.xxx.xxx
admin.email=mauroviana.s@hotmail.com
admin.pass=xxxxx
allowed.users.list=mauroviana.s@hotmail.com
-Initializing gmail smtp mail transport. Username : mauroviana.s@hotmail.com. SMTP host : smtp-mail.outlook.com:587
  • Didn’t find Let’s Encrypt certificates.
  • You didn’t specified ‘server.host’ or ‘contact.email’ properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
  • Found server certificate but no client certificate for ‘C:\BlynkServer\non-existing-client.crt’ path. Using one way ssl.
  • mauroviana.s@hotmail.com hardware joined.
Error clearly states the issue :
This should be empty :
server.ssl.cert=
server.ssl.key=
Before.
server.ssl.key.pass=xxxxxx
#server.host=.
#contact.email=.
Now.
server.ssl.cert=
server.ssl.key=.
server.host=.
contact.email=.
  • Didn’t find custom user certificates.
  • Automatic certificate generation is turned ON.
  • WARN - ATTENTION. Server certificate paths (cert : ‘C:\BlynkServer’, key : ‘C:\BlynkServer’) not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
  • Hardware plain tcp/ip server listening at 8442 port.
Your console shows error. Are your host available via 80 port?
Make sure that last little period is NOT actually in your server.properties file
I can not open port 80, error.
IP 192.168.xxx.xxxxThis text will be hidden = Server.
@Gunner
server.ssl.key= .
It was only time to copy and paste.
80 port is opened by default on all router. But Blynk server runs HTTP on port 8080 (security measure). Certificates request comes to port 80 (security measure, that proves you are the owner of host). So you have to forward request from port 80 to port 8080.
Look at this post
@Dmytro Is correct 8080 to 80?
Like this:
I have this error.
Logs:
@Fettkeewl, Did not work 0.0.0.0/0
Edit: Does that explain anything?
@mauroviana seems correct.
Regarding error:
I guess that you should wait a hour... From https://letsencrypt.org/docs/rate-limits/660:
Your internal ports should match that of your server.properties file.
Port 80 from external access goes to 8080 on internal access
Port 443 from external access to 9443 on internal.
Change in your first column in router settings. And you need my previous answer as well else you can’t login from outside your LAN
As this issue was growing in size, I moved it to it’s own topic so as not to crowd the announcement topic (any more :wink: ).
Is correct?
I get it.
OK sorry.
Port: 443 ok.
Port: 80 to 8080.
My router does not let me redirect the port 80 to 8080. I don’t know do this. Can help me?
@Fettkeewl Now I have:
Logs:
  • Starting up certificate retrieval process for host mc-casainteligente.ddns.net and email mauroviana.s@hotmail.com.
  • Registered a new user, URI: https:/acme-v01.api.letsencrypt…
  • Authorization for domain mc-casainteligente.ddns.net
  • Delivering content XPHlDwj6hPZoDSB1sic5vrvDn…
But I still can not open the admin page with seconds.
Now that you have proper settings assuming you added allowed IPs to be that 0.0…range
You must use your domain name to connect
With https specified. Not internal IP.
I.e
https://yourdomain/admin
It will automatically try to connect over port 443 for the https connection and will be redirected by your router to your computer on your computers port 9443. Make sure your pc firewall is not actively blocking your ports.
I admit that I have the same “Not Secure” error, but I just bypass it since it doesn’t really matter to me. I have generated certs from last year when I first installed Local Server, but I never access it outside my LAN anyhow. So how would one enter a domain name from within a local network? I mean… what domain name? I just have a Local Server IP - https://10.10.3.13:9443/admin - all locked off from my WAN side.
I don’t think you can unless you have some software installed that can solve it, don’t know of any. :neutral_face:
I use noip.com as my dns service, I connect to them when I enter my domain and they basically reroute me back to my network and then to my pc which has the blynk server running.
Using lets encrypt, needs a domain name to function apparently that is why it’s in discussion, unless you use it there is no need to fiddle with domain names, if you don’t need WAN access :slight_smile:
Thank you all, now it seems all right.
@Fettkeewl I was only able to open port 80 for Blynk by making this setting on the router.
You can tell me if that’s right, before it was like this.
Now it’s like this.
Do you have any opinion on safety
Sorry I don’t understand what is written on your pictures…
