How to use Virtual pin of arduino through blynk to perform multiple task when button linked to virtual pin is pressed..?
I’m trying to control robot path through UP, DOWN, LEFT and RIGHT through buttons in Blynk connected to virtual pins in Arduino. Is there any way I can push multiple commands under IF LOOP activating when virtual pin ==1 ?
Don’t forget to read the documentation :wink:
Try to stay away from blocking codes inside this function… but this is the normal way to use Virtual Pin control.
http://docs.blynk.cc/#blynk-main-operations-virtual-pins
BLYNK_WRITE(Vx) //Button Widget is writing to pin Vx
  if (param.asInt() == 1) { // activate next commands when button pressed ON
    // Do stuff here
    // and here
    // even here
thx, but there is one more problem when i tried to upload the code it says the following error (same appears for BareMinimum code):
Arduino: 1.8.3 (Windows 10), Board: “Arduino/Genuino Uno”
Archiving built core (caching) in: C:\Users\ANISHG~1\AppData\Local\Temp\arduino_cache_129790\core\core_arduino_avr_uno_4f102434c573a4283b83ba95af927dff.a
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can’t open device “\.\COM3”: The semaphore timeout period has expired.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
I have uploaded several codes in arduino before and they worked but it’s the first time this has happened. I checked port from device manager and its COM3 my arduino is updated and i also tried restarting my pc and changing arduino usb cable but nothing works…:confused:
https://www.google.com/search?q=avrdude%3A+ser_open()%3A+can’t+open+device+“\.\COM3”%3A+The+semaphore+timeout+period+has+expired.&oq=avrdude%3A+ser_open()%3A+can’t+open+device+“\.\COM3”%3A+The+semaphore+timeout+period+has+expired.&aqs=chrome..69i57j69i58&sourceid=chrome&ie=UTF-8
Restarting windows worked for it.
For Virtual pin problem, it is still not working…
Here’s my code:
int ma1=2;
int mb1=3;
int ma2=7;
int mb2=8;
#include <Servo.h>
int servoPin=5;
Servo myservo;
int i=0;
SoftwareSerial DebugSerial(0, 1); // RX, TX
char auth[] = "57ac041e2a054fdb8d2368735c403f8a";
BLYNK_WRITE(V0)
          myservo.write(param.asInt());
BLYNK_WRITE(V1)
        {/*command for UP*/
          if(param.asInt()==1){
            digitalWrite(ma1,LOW);
            digitalWrite(mb1,HIGH);
            digitalWrite(ma2,LOW);
            digitalWrite(mb2,HIGH);
          else{
            digitalWrite(mb1,LOW);
            digitalWrite(mb2,LOW);
BLYNK_WRITE(V2)
        {/*command for RIGHT*/
          else{
BLYNK_WRITE(V3)
          /*command for LEFT*/
          else{
BLYNK_WRITE(V4)
          /*command for DOWN*/
            digitalWrite(ma1,HIGH);
            digitalWrite(ma2,HIGH);
          else{
{myservo.attach(servoPin);
  DebugSerial.begin(9600);
  Blynk.begin(Serial, auth);
void loop(){
Should work… just perhaps not the way you want it to.
But it appears you haven’t set the pinmode() for any of those pins yet.
https://www.arduino.cc/en/Reference/PinMode
A post was split to a new topic: Problem with variable scope? [More information required]
