Hello all…i think i’ve a “modified” problems related to this topic…
how to “Reuse” Virtual Pin in other funnction or other void?
here is my code …
char auth[] = "VRe9eDqxmlAFUtzwhQfvOOmSIBLt272P";
char ssid[] = "Sherly";
char pass[] = "xxxxxxx";
// in Blynk app writes values to the Virtual Pin 1
// V3 LED Widget is blinking
void blinkLedWidget()
if (y == 1)
digitalWrite(D4, HIGH);}
else if (y == 0)
digitalWrite(D4, LOW);
BLYNK_WRITE(V10)
int y = param.asInt();
if (y == 1)
digitalWrite(LED_BUILTIN, HIGH);}
else if (y == 0)
digitalWrite(LED_BUILTIN, LOW);
pinMode(LED_BUILTIN, OUTPUT);
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
Blynk.notify(" Gawat koneksi putus");
//timer.run();
Hi @LOKI13 I’ve moved this to its own topic, mostly because you’ve not really explained the issue clearly.
I’m guessing (as I’ve said in the title that I’ve given to this new topic - please feel free to edit it) that your issue is with variable scope.
If you want to use the value that you’re obtaining from the V10 widget in the BLYNK_WRITE(V10) callback function elsewhere in your code then the variable that you use to store value needs to be global rather than local.
is telling the code to create a local integer variable called y and store the value from the widget ion this variable. Because it’s local, it can only be referenced within the BLYNK_WRITE(V10) function.
thats right… before i asking this question i do open blynk example…get data…etc…,and watch youtube video (Anna) …but all of them…they are use local variable…
Ive already usually arduino & Virtu*@# which is set a global variable even before void setup
and i think blynk is something new for me & interesting
Do you have a simple code that use “global” variable ?
lets say just blink a led using global Virtual memory,not digital pin and will be “acknowledge” to other Void
