I am doing a VirtualWrite with a float and all i get on the android app for Value and Gauge is %.3f is displayed. I did a pull yesterday, and am building on esp8266 standalone.
Could you please show your sketch? Floats works ok for me.
I’m having the same problem. I’m floating the temperature from a ds18b20 sensor and using virtual write but same problem.
I’ve been working a bit around with this issue myself to.
I to can’t get a float printed to value widget. And i dont know if supposed to work but at least for know i do a little workaround by converting to string. (Code in bottom of post)
Simple example that prints the %.3f error (using esp8266 and android):
char auth[] = "";
float testVal = 12.34;
Blynk.begin(auth, "", "");
timer.setInterval(3000, readTemp);
void readTemp()
Blynk.virtualWrite(5, testVal);
@vshymanskyy hymanskyy helped me in this thread with a related problem http://community.blynk.cc/t/compile-stalls-when-using-virtualwrite-on-a-string-variable/669
To summarize, i wanted to read a DS18B20 sensor and convert it to string (for Thingspeak) also i wanted the value printed in a value widget. Since i couldn’t get it to print the float value i used the value converted to string. For that you should use dtostrf(floatvar, StringLengthIncDecimalPoint, numVarsAfterDecimal, charbuf);
The example below prints the value with 2 decimal.
Hope it can be helpfull.
#include <OneWire.h>
//Data wire plugged to pin 2 (temp sensor)
#define ONE_WIRE_BUS 2
char auth[] = "";
sensors.begin();
void readTemp()
float floatTempC = sensors.getTempCByIndex(0);
char t_buffer[15];
dtostrf(floatTempC, 4, 2, t_buffer);
Blynk.virtualWrite(5, t_buffer);
I traced through the code, and see the define for ARDUINO_ARCH_ESP8266 in BlynkParam.cpp, and see where the float/double is supposed to get converted into a string. It looks ok to me, so not sure what is wrong.
void BlynkParam::add(float value)
len += sprintf(buff+len, "%2.3f", value)+1;
void BlynkParam::add(double value)
I tried this with the latest version, and still have the problem. Looked into it more and the problem is that the code is using printf(%f), but there isn’t actually support for %f. I have opened a ticket at https://github.com/blynkkk/blynk-library/issues/14
I also had trouble getting floats to work until I realized the analogRead must be recast.
BLYNK_READ(V0)
vbat = (float)analogRead(A0)/75;
Blynk.virtualWrite(0, vbat);
I would like to send the value 35.1.
Unfortunately, this does not work as desired.
Also the version 0.5.2 does not work.
float results = 35.1;
Send to terminal:
Serial.println (results); OK
Send to App:
Blynk.virtualWrite (V4, “35.1”); OK
Blynk.virtualWrite (V4, results); NOK (value in the app -0.0)
What can I do?
Which hardware and software do I use:
TI Launchpad: CC3200-LAUNCHXL REV4.1
Energia: 1.6.10E18
Blynk: v0.5.4
Blynk IOS APP: 2.23.0 (4)
Regards Martin
@MGAT Basically - this is a bug in most TI boards. I suggest you to report it to TI.
There’s a workaround. Try adding #define BLYNK_USE_INTERNAL_DTOSTRF
in Blynk/BlynkConfig.h
Hello vhymanskyy,
thank you for you reply.
Your solution works.
Thanks a lot.
Regards Martin
