Problems again with my PID.
Im using ESP8266, Arduino IDE 1.6.4, windows 8.
I haven’t been able to try on other setups.
I’m reading a DS18B20 sensor and gets a value as double variable.
I’m converting it to a string for sending it to ThingSpeak.
Now i want it sent to a Value widget in the app. I found out that sending the double just gave an error value on the widget. I can successfully send it as an int, but i would like 1 decimals precision. So i tried sending the String value since i read it supported strings. But when i do that, the IDE stalls at compiling. (the Program still responds fully, just tries to compile forever)
As soon as i comment out the Blynk.virtualWrite(9, stringVariable); it compiles nicely.
I stripped the code for everything else. Still does it.
Can someone tell me why? or test it for me, to see if its on my side that somethings wrong.
char auth[] = "auth";
double Input;
Blynk.begin(auth, "ssid", "pass");
void writeData() {
//set temp string for Thingspeak
char t_buffer[10];
String temp = dtostrf(Input, 0, 1, t_buffer);
Blynk.virtualWrite(7, temp); // this line gives the error for me.
Serial.println(temp);
UPD: Looks like Arduino String object can’t be cast to regular char buffers, unfortunately.
Actually this is bad, cause now you would have to write something like this:
And this comes from Arduino documentation… Well that’s odd, as for me
Anyway looking at you particular example, it would be different a bit (this should work):
Sorry for late reply. But thx a lot. It works perfect. The way you wrote the code seems more simple than my version. I don’t understand the reason for writing it the way i did. i just followed some examples i found. But this way i think it even makes sense to me ;).
Hi
I write some codes for my ESP8266_DHT22 Project.It will display temperature Celsius string and Read humidity percent string in the virtualWrite function.
