Hi All,
I am doing my project by using blynk and arduino mega.
This code is to control Relay by measuring temperature and humidity through dht11.
Now I programmed that Relay is off when the humidity is over 60 which is the fixed value.
However, I want to add slider or other input switch to set the humidity value on the app. And then the set value is sent from Blynk to Arudino. Therefore, Relay will be on or off, depending on the set value.
I’ve been trying it but failed.
Please anybody can help me?
Thank you.
#define BLYNK_PRINT SwSerial
#include <DHT.h>
char auth[] = "*****************************";
#define DHTPIN A1
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
int h = dht.readHumidity();
int t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
/*if (isnan(h) || isnan(t)) {
SwSerial.println("Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
if(h<60){
digitalWrite(52,HIGH);
else{
digitalWrite(52,LOW);
SwSerial.begin(9600);
pinMode(52,OUTPUT);
Blynk.begin(Serial, auth);
dht.begin();
