i used ESP01s for my first home automation project . and i connect it to blynk server using this code
char auth[] = "token code";
char ssid[] = "my home wifi ";
char pass[] = "pw";
all working properly i can on off my relay using blink app . i used GPIO0 pin in the ESP01s for control the relay . now i want to connect it to my google assistant . i used IFTTT for that
in applets i used blynk webhook and google assistant .
01 my first question how i put GPIO ( that pin GPIO0) to that code ?
02 in IOS blynk app in webhook only can idently V pink i cant find GPIO0 pin. how i name in that
I am facing the exact same problem. But your solution didn’t work for me. I am connecting IFTTT for Google Assistant. Will you please help me if I have missed any step?
Thanks buddy.
Is this command specific to my version of Blynk?
Does D8 correspond to gp0 in Blynk?
Value=1 is for ON?
How did you get the authorisation code?
I’m sorry to disappoint you.
Because, I’m there where I started with my problem.
I don’t know what digital Pin to use corresponding to gp0 in Blynk setting. Whole string of commands are known to me but for digital Pin number.
Thanks for input.
