BLYNK
How to automatically dual SSIDs for redundancy
esp8266
#1
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
char auth[] = "4bf59a2fddc046cea78ec8de6cba7831";
char ssid1[] = "ssid1";
char pass1[] = "pass1";
char ssid2[] = "ssid2";
char pass2[] = "pass2";
  Blynk.begin(auth, ssid1, pass1);
 while(Blynk.connect()==false){
  delay(500);
  Blynk.begin(auth, ssid2, pass2);
#2
Take a cue from this sketch
char auth[] = "YourAuthToken"; //Put Your Auth Token Here
//Array to store Network Credentials for different WiFi Networks
const char* KNOWN_SSID[] = {"Nucleus", "Factory Forward", "SSID3"}; //Put all Your WiFi Network Names
const char* KNOWN_PASSWORD[] = {"", "1234567809", "Pass3"}; //Put the WiFi Passwords in same order. For Open networks leave the password blank inside the double quotes.
const int KNOWN_SSID_COUNT = sizeof(KNOWN_SSID) / sizeof(KNOWN_SSID[0]); // number of known networks
boolean wifiFound = false;
int i, n;
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
// WiFi.scanNetworks will return the number of networks found
Serial.println(F("Scan start"));
int nbVisibleNetworks = WiFi.scanNetworks();
Serial.println(F("Scan Completed"));
if (nbVisibleNetworks == 0) {
Serial.println(F("No networks found. Reset to try again"));
while (true); // no need to go further, hang in there, will auto launch the Soft WDT reset
// if you arrive here at least some networks are visible
Serial.print(nbVisibleNetworks);
Serial.println(" network(s) found");
// check if we recognize one by comparing the visible networks
// one by one with our list of known networks
for (i = 0; i < nbVisibleNetworks; ++i) {
Serial.println(WiFi.SSID(i)); // Print current SSID
for (n = 0; n < KNOWN_SSID_COUNT; n++) { // walk through the list of known SSID and check for a match
if (strcmp(KNOWN_SSID[n], WiFi.SSID(i).c_str())) {
Serial.print(F("\tNot matching "));
Serial.println(KNOWN_SSID[n]);
} else { // we got a match
wifiFound = true;
break; // n is the network index we found
} // end for each known wifi SSID
if (wifiFound) break; // break from the "for each visible network" loop
if (!wifiFound) {
Serial.println(F("No Known Network identified. Reset to try again"));
while (true);
const char* ssid = (KNOWN_SSID[n]);
const char* pass = (KNOWN_PASSWORD[n]);
Serial.println("Blynk Connected"); //Connected and Authenticated with Blynk Server
thanks for prompt reply only one ssid connected other than.
#4
You with this code can put in array two or more ssid
#5
char auth1[] = "";
char ssid1,ssid2[] = "ssid1,ssid2";
char pass1,pass2[] = "pass1,pass2";
Blynk.begin(auth1,auth2, ssid1,ssid2, pass1,pass2);
#6
Please do not create multiple topics for same issue… I merged your 2nd topic Titled (Hi dears blynker can you all help me to add 2 ssid and 2 passwords i mean mukti ssid & passwords) here.
Please also format all posted code properly as required in the Welcome Topic or your posts will be deleted.
@amran Since you didn’t seem to listen, I fixed your code posting this time.
Next time follow the recommended formatting method please.
Blynk%20-%20FTFC
Oh, and use your words to supply details in the posts instead of simply posting code.
#9
We can help you learn to properly format posted code in this forum… as per the Welcome Topic :wink:
Blynk%20-%20FTFC
And again… please do NOT create multiple topics for same issue.
That character doesn’t exist on the Italian keyboard, damn it! You could have chosen a different one though! Every time I have to do copy&paste :stuck_out_tongue_winking_eye: :joy:
#11
Hold down the ALT key and use the numeric keypad to type the number 96
Another option is that in the Arduino IDE, when you select code then right-click you get this option:
When you paste in the forum you’dll see that teh IDE has added these code tags:
which displays correctly.
And another option:
Just copy and paste the following and then paste your code between the lines.
```cpp
#13
It appears that @saddys is already aware of that option and finds it a bit tiresome, hence my alternative suggestions.
Mine was a joke, it was never an insurmountable or tiresome problem. But having the [code] alternative for me will be very useful.
Thanks :slight_smile:
Another option:
If you have a spare Arduino board that’s compatible with the Keyboard library, and a spare pushbutton, wire the pushbutton between the defined pin and ground, and load the following sketch. With the board plugged into a USB port on your PC, you can push the button to generate the required characters. :wink:
#include <Keyboard.h>
#define BUTTON 2 // pin for button
  pinMode(BUTTON, INPUT_PULLUP);
  Keyboard.begin();
  if (digitalRead(BUTTON) == LOW) {
    Keyboard.print("```cpp\n```\n");
    delay(200); // delay for button debounce
    while (digitalRead(BUTTON) == LOW) {} // wait for button release
The “elegant” solution to “source code formatting” would be this :wink:
I’ve only spent a couple of hours working on this little plugin, but it would save a lot of posts for moderators. :smiley:
This forum already has those characters sitting there ready for the initial post… just create a new topic and chose the category… bingo… Copy/Paste for further posting.
#18
I had never seen this feature for new topics :slight_smile:
New users have no excuse to format the code :smiley:
Maybe this new button for those who reply would also be comfortable
Good point… I have no idea why your plugin idea never moved forward :thinking:
#20
As I say, mine was only a joke, I have always write a formatted code.
