Hello blynkers, i am currently new in programming and I need help with my project. I already successfully display the temperature & humidity in my Blynk app using DHT11. Can someone show me how use slider widget to control my desired temperature to activated my relay module? Any advice and help would be great. p/s: Iam using nodeMCU(esp8266), DHT11 and relay module. Below are my current code
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
dht.begin();
is this code correct? i try compiling and upload it receive no error. I slide the setpoint to 28 in my blynk app when the current room temperature is 30 but the relay still off.
#include <DHT.h>
int LED = 5;
char auth[] = "";
char ssid[] = "i";
char pass[] = "";
#define DHTPIN 0 // D3
float setpoint = 0;
bool relayoff = true;
const int relayPin = 5; // D1;
BLYNK_WRITE(V0) // slider widget
setpoint = param.asFloat();
void sendSensor()
return;
if((setpoint < t) && (relayoff == true))
digitalWrite(relayPin, 1); // assuming relay is active HIGH
relayoff = false;
dht.begin();
pinMode(relayPin, OUTPUT);
