No, you probably have your brackets or braces messed up somewhere within your sketch. Post it here and I will take a quick look.
#include <DHT.h>
int LED = 5;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 0 // D3
DHT dht(DHTPIN, DHTTYPE);
float setpoint = 0;
bool relaystatuschanged = false;
const int relayPin = 5; // D1;
BLYNK_WRITE(V0)// slider widget
setpoint = param.asFloat();
relaystatuschanged = true;
void sendSensor()
float h = dht.readHumidity();
if ((isnan(h)) || (isnan(t))) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
if((setpoint >= t) && (relaystatuschanged == true))
digitalWrite(relayPin, 1); // assuming relay is active HIGH
digitalWrite(relayPin, 0); // assuming relay is active HIGH
dht.begin();
pinMode(relayPin, OUTPUT);
Your bug is here:
You are missing the closing braces for the last if statement.
i am sorry, but where? there are already closing bracket there
No that was the closing bracket for the sendSensor() function.
Needs to be:
void sendSensor()
return;
Omg i forgot the semicolon on the last line. there was no further error but it still not working the relay keep turning on/off even after I change the digitalWrite(relayPin, 0) to 1 and 0
If you look back I posted this:
void sendSensor()
if (isnan(h) || isnan(t)) {
return;
if((setpoint < t) && (relaystatuschanged == true))
The two if statements are different to each other whereas you have identical if statements.
I have 2 if statements to cover when the temperature (setpoint slider) moves above DHT temperature, in addition to the temperature being below setpoint. As you have the sketch it is wholly expected for the the relay to go on and off.
iam sorry, i had corrected the mistakes but still the relay seem keep running even i change the slide value
current code
#include <DHT.h>
int LED = 5;
char auth[] = "";
char ssid[] = "i";
char pass[] = "";
float setpoint = 0;
void sendSensor()
return;
dht.begin();
Qās:
- When ESP boots, but before you move the slider, is the relay OFF?
- When you move the slider to a temperature below room temperature does the relay come on?
- If you move the slider above room temperature does the relay go off?
1.when ESP booting the relay OFF then after boot complete the relay will ON
2. It will continue to ON even after I move the slider below and upper than temperature room
3. It stays on
That suggests to me your relay is active LOW.
Change the 1 to a 0 and the 0 to a 1 in the 2 if statements.
it seem that my blynk project keep reconnecting to the server and i cant get proper value of temperature
Try changing the 1000L in your sketch to 10000L. Nobody needs to know the temperature every second and some sensors have 3 second read times.
Also keep a backup temperature t1 and set t to t1 if the isnan section is triggered.
Set t1 to t if isnan section is not triggered. This way you always have a valid temperature to compare against the setpoint.
iāve changed 1000L to 10000L. I had but why i cannot detect any temperature in my blynk app? Did i messed up the coding?
Remove the following from your sketch and anything in the app that might be tied to pin 5 (other than the relay).
int LED = 5;
Were you reliably getting the correct temperature readings earlier today?
Maybe move the DHT from pin 0 to pin 14.
i am getting the correct temperature earlier today.
iāve done your suggestion but still no readingā¦should i refresh the auth code?
iāve try using my dht tester code and the sensor work pretty well
You shouldnāt need to do this unless you have built a new project or moved to a different server.
Maybe the relay is killing the ESP.
What does Serial Monitor show if you add the following line as the first line of your sketch?
#define BLYNK_PRINT Serial /* Comment this out to disable prints and save space */
