#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <WiFi.h>
#include <DHT.h>
#include <stdlib.h>
#include <RFID.h>
#include <LiquidCrystal.h>
#include <ESP8266_Lib.h>
#include <Adafruit_Sensor.h>
IPAddress server_addr(***,***,***,**); // MySQL server IP
char user[] = "root"; // MySQL user
char password[] = ""; // MySQL password
WiFiClient client;
MySQL_Connection conn((Client *)&client);
char INSERT_SQL[] = "INSERT INTO fire_contents(Temperature1) VALUES ( %d)";
char query[128];
/*=====================BLYNK============================*/
char auth[] = "7390e1f9b6e14cb7bd5b452e3b222f1b";
char ssid[] = "No Wifi ";
char pass[] = "unityenz123";
// Hardware Serial on Mega,Due0
#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
/*=====================SENSOR VALUE=======================*/
//sensor values
int fval;
int fval2;
int gval;
int gval2;
int tval;
int tval2;
int hval;
int hval2;
/*=====================THRESHOLD VALUES=====================*/
//threshold Value
int flameth =500;
int gasth = 300;
int tempth = 40;
/*=======================OUTPUT PINS=======================*/
//All digital outputs
int ledf = 22;
int ledf2 = 23;
int ledg = 24;
int ledg2 = 25;
int ledt = 26;
int ledt2 = 27;
int buzzer = 28;
int waterpump=29;
int breaker = 50;
/*=======================INPUT PINS======================*/
//All analog Inputs
int Iflame = A0;
int Iflame2 = A1;
int Igas = A2;
int Igas2 = A3;
int Itemp = 30;
int Itemp2 = 31;
/*====================RFID DEFINITION=====================*/
/* Define the DIO used for the SDA (SS) and RST (reset) pins.*/
#define SDA_DIO 10
#define RESET_DIO 9
/* Create an instance of the RFID library */
RFID rfid(SDA_DIO, RESET_DIO);
int key1 [5]={154,31,192,73,12};
/*==============HARDWARE/SOFTWARE DEFINITION=============*/
// temp
DHT dht1(Itemp, DHT22);
DHT dht2(Itemp2, DHT22);
//LED Widget for app
WidgetLED led1(V10); //flame
WidgetLED led2(V11);
WidgetLED led3(V6); //temp
WidgetLED led4(V7);
WidgetLED led5(V13); //gas
WidgetLED led6(V14);
WidgetLED led7(V15); //Waterpump
//LCD Widget for app
WidgetLCD lcd1(V12); //lcd
// timer for blynkTimer
BlynkTimer timer1;
BlynkTimer timer2;
BlynkTimer timer3;
int al;
/* SETUP */
// Set ESP8266 baud rate
Serial.println("Connecting to database");
while (conn.connect(server_addr, 3306, user, password) != true) {
delay(200);
Serial.print ( "." );
Serial.println("");
Serial.println("Connected to MySQL Server!");
timer.setInterval(500L, ValuesUpdate);
timer1.setInterval(1000L, APP_LED);
timer2.setInterval(1000L, Alarm_APP);
timer3.setInterval(1000L, disarm);
// PINMODE DFINITION
for (int i = 22; i<31 ; i++){
pinMode(i,OUTPUT);
pinMode(Iflame,INPUT);
pinMode(Iflame2,INPUT);
pinMode(Igas,INPUT);
pinMode(Igas2,INPUT);
// TEMP SENSOR
dht1.begin();
dht2.begin();
// RFID
/* Enable the SPI interface */
SPI.begin();
/* Initialise the RFID reader */
rfid.init();
/* LOOP */
timer1.run();
timer2.run();
if(digitalRead(buzzer)||digitalRead(waterpump)||digitalRead(breaker)){
timer3.run();
/* FUNCTIONS */
void Sensor_Readings(){
fval = analogRead(Iflame);
fval= abs(fval-1023);
Serial.print("Flame 1 =");
Serial.println(Iflame);
fval2 = analogRead(Iflame2);
fval2= abs(fval2-1023);
Serial.print("Flame 2 =");
Serial.println(fval2);
gval = analogRead(Igas);
Serial.print("Gas 1 =");
Serial.println(gval);
gval2 = analogRead(Igas2);
Serial.print("Gas 2 =");
Serial.println(gval2);
if(!(isnan(dht1.readTemperature()))){
tval = dht1.readTemperature();
Serial.print("Temp 1 =");
Serial.println(tval);
sprintf(query, INSERT_SQL,tval);
Serial.println(query);
if(!(isnan(dht2.readTemperature()))){
tval2 = dht2.readTemperature();
Serial.print("Temp 2 =");
Serial.println(tval2);
if(!(isnan(dht1.readHumidity()))){
hval = dht1.readHumidity();
Serial.print("Humi 1 =");
Serial.println(hval);
if(!(isnan(dht2.readHumidity()))){
hval2 = dht2.readHumidity();
Serial.print("Humi 2 =");
Serial.println(hval2);
void ValuesUpdate(){
Sensor_Readings();
Blynk.virtualWrite(V2,tval);
Blynk.virtualWrite(V3,tval2);
Blynk.virtualWrite(V4,hval);
Blynk.virtualWrite(V5,hval2);
Blynk.virtualWrite(V8,gval);
Blynk.virtualWrite(V9,gval2);
void APP_LED(){
//flame 1
if(fval>flameth){
led1.on();
else{
led1.off();
// flame 2
if(fval2>flameth){
led2.on();
else{
led2.off();
// temp 1
if(tval>tempth){
led3.on();
else{
led3.off();
// temp 2
if(tval2>tempth){
led4.on();
else{
led4.off();
// gas 1
if(gval>gasth){
led5.on();
else{
led5.off();
// gas 2
if(gval2>gasth){
led6.on();
else{
led6.off();
void Alarm_APP(){
if(Sys_state(fval,tval,gval)||Sys_state(fval2,tval2,gval2)){
lcd1.clear();
if(Sys_state(fval,tval,gval)){
led7.on();
lcd1.print(0,0,"ALARM TRIGGERED");
lcd1.print(0,1,"SHARED_FAC Room1");
else{
led7.on();
lcd1.print(0,1,"SHARED_FAC Room2");
else if(thres_state(fval2,tval2,gval2)){
lcd1.clear();
// led7.off();
lcd1.print(0,0,"SYSTEM UNSAFE");
else if(thres_state(fval,tval,gval)){
lcd1.clear();
// led7.off();
else if(!digitalRead(buzzer)&&!digitalRead(waterpump)&&!digitalRead(breaker)){
led7.off();
lcd1.print(0,0,"SYSTEM SAFE.....");
lcd1.print(0,1,"Rm1-OK....Rm2-OK");
BLYNK_WRITE(V16){
flameth = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("flame threshold is = : ");
Serial.println(flameth);
BLYNK_WRITE(V17){
gasth = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("Gas threshold is = : ");
Serial.println(gasth);
BLYNK_WRITE(V18){
tempth = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("Tempurature threshold is = : ");
Serial.println(tempth);
int Sys_state(int flame,int temp,int gas){ //buzzerr alarm indicating function
if((flame > flameth) && (temp > tempth)){
return 1;
else if(gas >= gasth){
return 1;
else{
return 0;
int thres_state(int flame,int temp,int gas){ //buzzerr alarm indicating function
if((flame > flameth) || (temp > tempth)||(gas > gasth)){
return 1;
else{
return 0;
void led(int flame,int temp,int gas,int Room){ //Led function turn on and off
switch (Room){
case 1:
if(flame> flameth){
digitalWrite(ledf,HIGH);
else{
digitalWrite(ledf,LOW);
if(temp > tempth){
digitalWrite(ledt,HIGH);
else{
digitalWrite(ledt,LOW);
if(gas> gasth){
digitalWrite(ledg,HIGH);
else{
digitalWrite(ledg,LOW);
case 2:
if(flame> flameth){
digitalWrite(ledf2,HIGH);
else{
digitalWrite(ledf2,LOW);
if(temp > tempth){
digitalWrite(ledt2,HIGH);
else{
digitalWrite(ledt2,LOW);
if(gas> gasth){
digitalWrite(ledg2,HIGH);
else{
digitalWrite(ledg2,LOW);
void disarm(){
/* Has a card been detected? */
if (rfid.isCard()){
/* If so then get its serial number */
rfid.readCardSerial();
int disarmval=0;
for(int i=0;i<5;i++)
if((rfid.serNum[i])==key1[i])
disarmval++;
if(disarmval==5){
led7.off();
Tobe honest, you’re trying to do quite a lot with one single device.
Doing three digital reads in the void loop isn’t something that the Blynk library is going to like very much.
You do t actually need 4 Blynk Timer objects, one object can support up to 16 instances so that would save you some processing power, but keeping-up a Blynk and MySQL server connection at the same time is asking quite a lot of the ESP.
Unless the MySQL database is essential for other things, I’d think about using the Blynk database to store that data instead.
Alternatively, I suppose you could have a separate ESP dvi e with its own Blynk Auth code and Bridge code that takes the Blynk actions and writes them to MySQL.
Using Node-Red and MQTT is also an option, as there are Blynk and MySQL plugins available for Node-Red.
how would i read the values from the blynk server to nodered… your advice would be greatly appreciated…
Using the Blynk ws contrib for Node-Red.
More info here:
Pete,
Good day that is quite an awesome project you have their, but i was trying to create a node red flow to read the temperature values from blynk server to the output panel of node red but nothing showed here is my flow
You’ll get he temperature reading from V2 when the value changes (in just the same way that BLYNK_WTRITE(V2) is triggered in C++).
To force the temperature value to be outputted from the server you’ll need to add a Sync node and inject something in to it to trigger it (a timestamp is sufficient).
Try reading this to troubleshoot the HTTP GET error:
ok Pete,
so what your saying in the first flow i would recieve the value…
in the first flow you should see the temperature value when the Blynk server value is updated. If you’re pushing a new temperature value every 5 seconds from a device then it should appear in Node-Red every 5 seconds.
If the value is sitting on the server but isn’t being refreshed then a Sync-all or Sync-V2 will force the server to push the value out.
I have one more question i want to write the values to a mysql database but i am encountering an error in the function node. here is my node flow
msg.topic=‘INSERT Into fire_contents (Temperature1) values(?)’;
return msg;
that is what is in my function node
Pete, i must say thanks the problem that was encountered is solved
That’s great.
So have I managed to convert another follower over to the dark side of Node-Red?
i guess you have
Yay!
