Hello, everybody! Here is a situation: Blynk docs says that I have to ceep clean a loop cycle as far as I can. Ok, I have a sensor, that generate suddenly some digital signal in very short time delta. I know, that there is a BlynkTimer, that I can configure to check if there any signals.
The question is: do I need to configure BlynkTimer on some 100ms interval, or check this value on loop cycle?
Thanks.
It depends on the type of sensor, it if it’s a digital signal then you could look at using interrupts.
However, if it’s a sensor that sends data via a serial interface then it’s not so easy.
Thanks for advice, will look for interrupts! There is a nice example in library: Sync->ButtonInterrupt.
I actually don’t like the Blynk interrupt example in sketch builder.
This explains why:
Try answer this for me: I need to replace a spark-plug (I think) in my cars engine. The car is (mostly) blue and has 4 tires. How to proceed?
Get the hint? ![]()
On this rare occasion I might have to correct you Pete! ![]()
While pampering my first born I found out that my UNO has a serial buffer!!
Trial and error made me abandon interrupts since it didn’t work well with Blynk. As long it’s “real” data and not a boolean value your’e getting, a semi-fast timer might do the trick!
But it all depends on what kinda car you drive ![]()
